Dear reader,
I am making a robot that avoids light (gets your beer out of the sun) for a school project. I am using a 4x4 ultrasonic sensor car. The car works. And i have a code which turns a LED on when the Ldr is recieving light.
My question is: how do i connect both codes so that the code for the ultrasonic 4x4 starts running when there is enough light detected by the Ldr?
This is the code for the 4x4:
// Setup the servo motor
#include <Servo.h>
Servo myservo;
int servposnum = 0;
int servpos = 0;
// Setup Motor A (front and rear) pins
int enableA = 1;
int pinA1 = 3;
int pinA2 = 2;
// Setup Motor B (front and rear) pins
int enableB = 6;
int pinB1 = 5;
int pinB2 = 4;
// Setup Ultrasonic Sensor pins
#define trigPin 8
#define echoPin 9
// The setup code goes here and runs once only
// Configure the pin modes for each drive motor
pinMode (enableA, OUTPUT);
pinMode (pinA1, OUTPUT);
pinMode (pinA2, OUTPUT);
pinMode (enableB, OUTPUT);
pinMode (pinB1, OUTPUT);
pinMode (pinB2, OUTPUT);
// Configure the pin modes for the Ultrasonic Sensor
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
// Turn pin into servo driver. Calls pinMode. Returns 0 on failure.
myservo.attach(7);
// Main code goes here and will run repeatedly:
car(); // function keeps moving car forward while distance > 15cm
avoid(); // function makes car go back, turn slightly right to move forward in new direction
// Create motor functions
void motorAforward() {
digitalWrite (pinA1, HIGH);
digitalWrite (pinA2, LOW);
void motorBforward() {
digitalWrite (pinB1, LOW);
digitalWrite (pinB2, HIGH);
void motorAbackward() {
digitalWrite (pinA1, LOW);
digitalWrite (pinA2, HIGH);
void motorBbackward() {
digitalWrite (pinB1, HIGH);
digitalWrite (pinB2, LOW);
void motorAstop() {
void motorBstop() {
void motorAcoast() {
void motorBcoast() {
void motorAon() {
digitalWrite (enableA, HIGH);
void motorBon() {
digitalWrite (enableB, HIGH);
void motorAoff() {
digitalWrite (enableA, LOW);
void motorBoff() {
digitalWrite (enableB, LOW);
// Setup movement functions
void backward (int duration) {
motorAforward();
motorBforward();
delay (duration);
void forward (int duration) {
motorAbackward();
motorBbackward();
delay (duration);
void right (int duration) {
motorAbackward();
motorBforward();
delay (duration);
void left (int duration) {
motorAforward();
motorBbackward();
delay (duration);
void coast (int duration) {
motorAcoast();
motorBcoast();
delay (duration);
void breakRobot (int duration) {
motorAstop();
motorBstop();
delay (duration);
void disableMotors() {
motorAoff();
motorBoff();
void enableMotors() {
motorAon();
motorBon();
// Setup Ultrasonic Sensor distance measuring
int distance() {
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
return distance;
// Setup the main car function
void car() {
int distance_0;
distance_0 = distance();
// Keep moving forward in a straight line while distance of objects > 15cm
while(distance_0 > 15)
// Keep moving servo motor back and forth to scan surroundings
// This allows the ultrasonic sensor to see more to its left and right
if(servposnum == 0)
myservo.writeMicroseconds (1900);
servposnum = 1;
delay(100);
else if(servposnum == 1)
myservo.writeMicroseconds (2200);
servposnum = 2;
delay(100);
else if(servposnum == 2)
servposnum = 3;
delay(100);
else if(servposnum == 3)
myservo.writeMicroseconds (1600);
servposnum = 1;
delay(100);
motorAon();
motorBon();
forward(1);
breakRobot(0);
void avoid()
// Go back and turn slightly right to move car in new direction if object detected < 15cm away
backward(500);
right(360);
This is the code that im using for the ldr and the LED:
const int ledPin = 13; //the number of the LED pin
const int ldrPin = A0; //the number of the LDR pin
pinMode(ledPin, OUTPUT); //initialize the LED pin as an output
pinMode(ldrPin, INPUT); //initialize the LDR pin as an input
int ldrStatus = analogRead(ldrPin); //read the status of the LDR value
//check if the LDR status is <= 300
//if it is, the LED is HIGH
if (ldrStatus <=500) {
digitalWrite(ledPin, LOW); //turn LED off
Serial.println("LDR is DARK, LED is off");
else {
digitalWrite(ledPin, HIGH); //turn LED on
Serial.println("---------------");
I hope someone is able to help me! i am quite new to coding.
