light delay light
Below is my code I am trying to push button1(STR) to turn on light1(SCR) then after 10sec delay turn on light2(COM), then push button2(STO) to turn off light2(COM) then after delay turn off light1(SCR). Is there a problem with my code?
int STR = LOW;
int STO = LOW;
int SCR = LOW;
int COM = LOW;
 pinMode(2, INPUT);
 pinMode(3, INPUT);
 pinMode(4, OUTPUT);
 pinMode(5, OUTPUT);
 STR = digitalRead(2);
 STO = digitalRead(3);
 unsigned long TimerA;
 unsigned long TimerB;
 if (STR == HIGH) {
   TimerA = millis();
   SCR == HIGH;
 if (millis() - TimerA >= 1000UL) {
   COM == HIGH;
 if (STO == HIGH) {
   TimerB = millis();
   COM == LOW;
 if (millis() - TimerB >= 1000UL) {
   SCR == LOW;
Tried doing digitalWrite but it gave me an error that said I needed to define digitalWrite that is why I changed it.
benkishpaugh:
If you say so.
I'd rather see the code you say didn't compile.
In code tags this time, please.
I found the original code and tried using it but kept getting errors so I kept changing till the errors went away and ended up with the mess I showed before. I am not very familiar with arduino syntax still in early stages of learning but done with the book I got with the kit.
unsigned long TimerA    "ALWAYS use unsigned long for timers..."
if digitalReadA==Down
  then  TimerA= millis() , digitalWriteA ON
if millis()-TimerA >= 15000UL
  then digitalWriteA Off
if digitalReadB==Down
  then  TimerB= millis() , digitalWriteB ON
if millis()-TimerB >= 15000UL
  then digitalWriteB Off [code]
[/code]
Not sure if this makes it better or worse what do you think?
if (digitalRead(2)==HIGH) {
    TimerA = millis() , digitalWrite(4);}
    digitalWrite(5);}
  if (digitalRead(3)==HIGH) {
    TimerB = millis() , digitalWrite(5);}
    digitalWrite(4);}
I suspect that this is not doing what you want.
    TimerA = millis();
    digitalWrite(4);
might do what you want, but I have not studied your program.
It actually will not compile now. My first post explains what I was trying to accomplish and has all the code I developed and it did not do anything wiring is correct but no magic. :confused:
Please post "it"
Thank you for the help. :slight_smile:
