I made the program below that at 12:00 it starts fading the light to switch on and at 18:00 it starts to fade them off. It also read the pin output value and if the pin is off it allows it to switch on, if the time is between the set values(it is used incase of a power failure). It is currently set at 100% brightness and when I change the brightness to any other value, it reads that the pin is off (‘digitalRead(led)’) and restart the sequence to switch on again every minute. Any ideas how to fix it?
#include <DS3231.h>
//Changable Vars
int fadeTime = 1; //Fade Time
int onHour = 12; //Light On Hour
int onMin = 00; //Light On Minute
int offHour = 18; //Light On Hour
int offMin = 00; //Light On Minute
int led = 9; //Set pinout with PWM
int maxBrightness = 100; //LED Brightness Percentage
int val = 0; //Store value
//Set up Vars
DS3231 rtc(SDA, SCL);
Time t;
void start();
pinMode(led, OUTPUT);
rtc.begin();
maxBrightness = map(maxBrightness,0,100,0,255); // Map percentage to output range.
t = rtc.getTime();
// Send Day-of-Week
//Serial.print(rtc.getDOWStr());
//Serial.print(" ");
// Send date
Serial.print(rtc.getDateStr());
Serial.print(" -- ");
// Send time
Serial.print(rtc.getTimeStr());
val = digitalRead(led); // read the input pin
Serial.println(val); // debug value
if (val == 0 )
if (t.hour >= onHour && t.min >= onMin && t.hour < offHour) //Check Time
on();
if (val == 1)
if (t.hour == offHour && t.min == offMin) //Check Time
off();
// Wait one second before repeating
delay (1000);
void on()
// Fade script
for (int i = 0 ; i <= maxBrightness; i++)
analogWrite(led, i);
delay(((fadeTime * 60000)/306));
Serial.println(" mil sec ");
Serial.print(((fadeTime * 60000)/maxBrightness));
Serial.print(" PWM " );
Serial.print(i);
delay(60000); // Stay On
analogWrite(led, maxBrightness);
void off()
// Fade script
for (int i = maxBrightness ; i >= 0; i--)
Serial.print(i);
delay(60000); // Stay Off
analogWrite(led, 0);
