light meter sketch problem
hi guis ,i am new to arduino and i am trying to build a light meter (lx).I think my sketch is wrong,the lcd dont work.The serial …works fine…HELP
i ATTACH BELLOW THE SKETCH
sketch_mar22a_LIGHTMETRtestlcd.ino (826 Bytes)
the lcd dont work
Doesn’t work in what way ?
No text on screen ?
Wrong text on screen ?
Does it work with the LCD “Hello World” example ?
Here is how you should have posted your code
//Light Intencity Measurement
//www.circuits4you.com
//Include LCD library
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
double Light (int RawADC0)
  double Vout = RawADC0 * 0.0048828125;
  //int lux=500/(10*((5-Vout)/Vout));//use this equation if the LDR is in the upper part of the divider
  int lux = (2500 / Vout - 500) / 10;
  return lux;
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  Serial.print("Light Intensity:");
  Serial.print(int(Light(analogRead(0))));
  Serial.println("Lux");
  lcd.setCursor(0, 0);
  lcd.print("Light Intensity:");
  lcd.setCursor(0, 1);
  lcd.print(int(Light(analogRead(0))));
  lcd.println("lux");
Using code tags
No text on screen.I will learn,thanks. Lcd just have blu light and nothing else...
Has the LCD got a contrast potentiometer on the back ? Does the "Hello World" example work ?
thank you your point help me!!!!!
nektarios-25ma: thank you your point help me!!!!!
So the problem was the contrast pot ?
