Light Screamer Project (HELP NEEDED)
I'm basically trying to make the piezo buzzer scream when there's light and play music when it's dark. To do so, I used a photoresistor which decreases in resistance with more light. I'm trying to make the code so that when there is light it screams once and when there is darkness it plays music once. I also want it to stop the music and quickly scream once there is light.
The problem with my code is that it screams over and over again and the music doesn't stop. Below is my code; it would be great if someone gave me an advice to correct it. Thanks.
 * The calculation of the tones is made following the mathematical
 * operation:
 * timeHigh = period / 2 = 1 / (2 * toneFrequency)
 * where the different tones are described as in the table:
 * note   frequency   period   timeHigh
 * c    261 Hz    3830    1915
 * d   294 Hz   3400   1700
 * e   329  Hz  3038  1519
 * f 349 Hz 2864 1432
 * g 392 Hz 2550 1275
 * a 440 Hz 2272 1136
 * b 493 Hz 2028 1014
 int speakerPin = 2;                                             // pin to use to drive speaker
 char names[] = {'c','d','e','f','g','a','b'};                    // List of notes we want to be able to play
 int rangeOfNotes = 8;
 int tones[] ={1915, 1700, 1519, 1432, 1275, 1136, 1014, 956};
 int length = 42;
 char notes[] = "ccggaagffeeddcggffeedggffeedccggaagffeeddc ";
 double beats[] = {1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4};
 int tempo = 300;
 int lightSensor = 5;     //Analog pin Light Resistor is connected to
 int darknessThresh = 500;
  pinMode(speakerPin,OUTPUT);
void Scream()
  digitalWrite(speakerPin, HIGH);
  delay(1500);
  digitalWrite(speakerPin,LOW);
 void playNote(char note, int duration)                         //plays the note "note" for the time "duration"
        //play the tone corresponding to the note name
   for (int i = 0; i < rangeOfNotes; i++)
   if (names[i] == note){
   playTone(tones[i], duration);
 void playTone(int tone, int duration)
   for (long i = 0; i < duration *1000L; i += tone * 2)
   delayMicroseconds(tone);
   digitalWrite(speakerPin, LOW);
void Sing()
   for (int i = 0; i < length; i++)
       if (notes[i] == ' ')
         delay(beats[i] * tempo);
       {playNote(notes[i], beats[i] * tempo);}
       delay(tempo/2);
  int lightLevel = analogRead(lightSensor);
  Serial.print("Light Level = ");
  Serial.println(lightLevel);
  if(lightLevel < darknessThresh)
    Scream();
  if(lightLevel > darknessThresh)
   Sing();
You need to keep track of whether you last screamed or sung and check that status before you do it again. One way might be to have a byte variable called LastAction and set it 0 for no action yet, 1 for Sung and 2 for screamed. If it's dark, check that your last action wasn't a scream before you do scream. When you do, set LastAction. Same thing for singing. You could do the same thing with a couple of booleans too.
