light sensing off and on 5 m white LED strip
I’m new to Arduino and electronics and I’m trying to make a lighting system that goes on when it senses light (it is for inside a wardrobe).
I’ve made a simple proof of concept with a simple LED and now i’m moving on to the LED strip and external power supply.
So I’ve got
12 V DC 3 A power supply
Arduino Uno
Breadboard
5 M LED strip
link for pic https://dl.dropboxusercontent.com/u/35749900/WP_000782.jpg
The lights work when connected through the breadboard directly to power supply but not when I try to adapt my set up that worked with the LED. On the picture the power goes in at the top right, LED bottom right. There’s a TIP120 transistor in there too. In fact, I tried to base it on this http://blog.dcxn.com/2013/03/03/dimming-a-12v-led-strip-with-an-arduino/
Any ideas whee I’m going wrong as it’s no longer lighting with this set up
Here’s the code I’m running
int sensePin = 0;
int led = 9;
int brightness = 0;
int fadeAmount = 0;
  analogReference(DEFAULT);//isn't necessary
  pinMode(led,OUTPUT);
  int val = analogRead(sensePin);
  if (val > 350)
    if(brightness != 255)
      brightness = 0;
      for(brightness = 0; brightness <= 255; brightness += 5)
        analogWrite(led,brightness);
        delay(50);
      brightness = 255;
    brightness = 0;
