light sensor controlling LED
my light sensor code is half working as it turns on 1 light when it is dark and turns it off when it is not. Two problems, however. The light is green I need it to be white and also only one light is lighting up. Also, want the code to fade the light gradually. (my codes below) any help is appreciated.
#include <FastLED.h>
int LDR_Pin = A0;
int sensorValue;
const int ledPin = 5;
const int LedOn_StartMinLightLevel = 150;
#define LED_PIN 5
#define NUM_LEDS 35
CRGB leds[NUM_LEDS];
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
Serial.flush();
sensorValue = analogRead(A0);
Serial.println(analogRead(LDR_Pin));
int outputValue = 400 - sensorValue;
if(outputValue < LedOn_StartMinLightLevel)
outputValue =0;
int resultValue = map (outputValue,0,400,0,255);
digitalWrite(ledPin,resultValue);
FastLED.show();
delay(100);
op4732550:
int LDR_Pin = A0;
int sensorValue;
#define LED_PIN 5
#define NUM_LEDS 35
Serial.flush();
outputValue =0;
FastLED.show();
delay(100);
What is the value of 'sensorValue' in light versus in dark?
they are like 2 to 8. usually not highter than 18
  sensorValue = analogRead(LDR_Pin);
  Serial.println(sensorValue);
Please remember to use code tags when posting code
I can't see where you set the colour of the LEDs
i didn't see the colour and sill only one lights up. Im not used to working with led strips.
