I'm trying to create a program for a microcontroller project. I've written most of the code but am stuck on how to get it to all function together. Essentially what I am doing is using a potentiometer, a photoresistor, 2 LED's, and a small piezoelectric speaker.
What i am doing is comparing voltage between PR and pots to control when sound will play and what LED will light up. I've written separate programming allowing the LED's to function as intended, but when i incorporate the void note function it will only allow either the idle LED to be on or for the alarm LED and speaker to play. I've used a if and else if statements. I can't figure out how to get it all to run smoothly. Any input would be much appreciated
P.S.
This is a beginner Microcontroller class so everything is pretty basic.
Your big mistake.
You should write a little code, then test. Then write a little more then test.
Lets get thing right, it is not called the void note function, it is called the note function. Void is not part of its name it is the value it returns.
And you have the code to look at. What chance does anyone else stand trying to spot your error without the code you have. Does it use the delay function, that is what trips most beginners up?
Please read this:-
How to use this forum
Post you code correctly - it tells you how in the rules so we will know if you can't be arsed reading them.
In the mean time read this:-
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
