Anyone know a good light sensor to plug into an I/O slot? Hitec robonova sensor is unavailable and bare wire photoresistor with bare wire resistor won't work...
Why wont a photoresistor work for sensing light? I guess we need to know what are you using the sensor for?
Why don't you get solar panels then?
You could get a few Lego Mindstorm NXT light sensors
http://shop.lego.com/ByTheme/Product.aspx?p=9844&cn=17
Oh dear, someone mentions something expensive on the forum!
They are not quite as simple as just plugging it in...
Are we here to learn or read a simple instruction manual? ;D
Some people already did it, I'm sure we can find some code here and here.
I lost the link, but this detector is WAYYY cheaper than the TCS3200D discontinued brother. It was over $50 if I remember correctly.
Oh I was not saying alternatives were cheaper but it's still expensive
He asked for a suggestion ;D
But yeah...expensive. On the bright side, it does detect different light colors other than white and black! Not that you can get the same thing for about $5, but... :
The lego one doesn't detect colour very well at all.
This is my first robot. I don't know how to solder anything, don't want to have to solder anything right now, and certainly don't have the tools. That's why bare wire won't work.
I actually am looking for a photoresistor... sorry for the odd wording.
Well if it is your first robot then I would definitely recommend you get the tools.
They will come in very handy.
Mowcius
Like this one?
For right now I want one with an I/O plug; I want it easy since this is my first robot; sorry if I'm confusing you [smiley=tongue.gif]
There are lot's of different connectors is the problem.
Is this what you're looking for?
http://catalog.orteches.com/shopping/index.php?main_page=product_info&cPath=83_85&products_id=278
or
http://www.robotbuy.ca/products/Hitec_Robonova_Light_Sensor-259-9.html
Maybe this with an added dual female coupler?
http://www.vexrobotics.com/products/accessories/sensors/276-2158.html
BTW, when he says this is his first robot I believe he's talking about this...
and not this...
If you're 100% against learning to solder (you really should) then get a solderless breadboard and set it up like this;
(You can ignore the LED on 13)
That's what I want, biocow, and no, I am not building the robonova. I have designed my own robot, just using this light sensor.
Thanks for the links. I'll see if they have it in stock, although it is discontinued.
