Light Sequence Creator Arduino Hub Project Uno R3 /PC/Schem / Not Communicating
Sorry; not sure what category to bin this to :can you direct it to the right category
Issue : Software program -Light Sequence Creator ( C++) uploaded to Code Block 8.02-IDEplatform . No errors during build . PC via USB cable to Uno R3 , when hit build and run Green light and one small yellow led come on the R and T small leds not on Program to Uno to schematic appears not to be communicating . Will check connections again but don't think that is the issue - see attached - code is light_ sequencer.c Can't use Arduino IDE - file extension not .ino WHAT AM I Doing Wrong !
The Project is on the Arduino Hub " Light Sequence Creator " I left the same comment on the Hub
Also noticed that in the program comments line 15 , etc "Pin connected to ST_CH,SH_CP, DS ; pins latch Pin 11, clockPin 13, dataPin12 Pin #"s do not match the data sheet pin #'s for example on 74HC595 ST_CP is Pin 12 not pin 11 and on SN74HC pin 12 is termed RCLK not ST_CP not sure that is an issue ;thought as long as I followed the schematic ( see attached ) I'll be okay ; I have the SN74HC595 Is the real issue a .c file and platform ? versus Arduino IDE and ino. extension ?
Had to delete bottom half of code i exceeded that allowable # of characters
#include <LiquidCrystal.h>
#define ARR_SIZE 16 // CHANGE this to any number of frames
#define LIGHTS 8
// Controls the game button inputs
const int btn1 = 7, btn2 = 8, btn3 = 9, btn4 = 10;
// Variable for reading the pushbutton status
int bs1 = 0, bs2 = 0, bs3 = 0, bs4 = 0;
// Pin connected to ST_CP of 74HC595
const int latchPin = 11;
// Pin connected to SH_CP of 74HC595
const int clockPin = 13;
// Pin connected to DS of 74HC595
const int dataPin = 12;
// Holders for information you're going to pass
byte data;
// Used to read either 1 or 0
bool ArrOne[ARR_SIZE][LIGHTS] = {false}; // animation
// Translated for the register as bytes
byte lightArrOne[ARR_SIZE] = {0xFF};
// Variables to affect the animation
int animSpeed = 50; // ms between each frame
int loopCount = 5; // amount of times it will run
// Controls LCD Values
const int rs = 15, en = 14, d4 = 3, d5 = 4, d6 = 5, d7 = 6;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// Set each button up
pinMode(btn1, INPUT_PULLUP);
pinMode(btn2, INPUT_PULLUP);
pinMode(btn3, INPUT_PULLUP);
pinMode(btn4, INPUT_PULLUP);
// Set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Set register latch
pinMode(latchPin, OUTPUT);
PrintMenu();
bs1 = digitalRead(btn1);
bs2 = digitalRead(btn2);
bs3 = digitalRead(btn3);
bs4 = digitalRead(btn4);
// Play the anim
if(bs1 == HIGH)
bs1 = LOW;// just used to prevent bad/double input
delay(150);
Play();
// Modify the anim
} else if(bs2 == HIGH)
bs2 = LOW;
delay(150);
Create(ArrOne);
// Change the speed of the anim
} else if(bs3 == HIGH)
bs3 = LOW;
delay(150);
SetSpeed();
// Change the number of times the anim will play
} else if(bs4 == HIGH)
bs4 = LOW;
delay(150);
SetLoop();
PrintMenu();
delay(150);
// Function to print info for the main menu
void PrintMenu()
ClearScreen();
lcd.print("1-Play 3-Speed");
lcd.setCursor(0, 1);
lcd.print("2-Create 4-Loops");
// Function to print info for creating a frame
void PrintCreate(bool Arr[][LIGHTS], int frame, int _bit)
ClearScreen();
lcd.print("Frame:");
lcd.print(frame+1);
if(frame < 9)
lcd.print(" ");
for(int j = 0; j < _bit; j++)
lcd.print(" ");
lcd.print("v");
lcd.print(" ");
for(int j = 0; j < 8; j++)
lcd.print(Arr[frame][j]);
// Function to print info for setting the speed
void PrintSetSpeed()
ClearScreen();
lcd.print("Set Speed(ms)");
lcd.print(animSpeed);
// Function to print info for changing the number of animation loops
void PrintSetLoop()
ClearScreen();
lcd.print("Set Loop Count");
lcd.print(loopCount);
// Function to play the animation with the given parameters
void Play()
// The animation
for(int count = 0; count < loopCount; count++)
for(int i = 0; i < ARR_SIZE; ++i)
//load the light sequence you want from array
data = lightArrOne*;*
@aedford1551
Use the links below to help you post code etc.
Take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Multiple posting for the same topic is also frowned on !
Read the forum guide.
@aedford1551
TOPIC MOVED and MERGED.
Please don't DUPLICATE in future but ask for the topic to be moved to the correct section.
Could you take a few moments to Learn How To Use The Forum.
It will help you get the best out of the forum.
This topic was automatically closed after 63 days. New replies are no longer allowed.
