Light to control DC Motor
I've only had barely 1 month to learn Arduino for my new media art class and we've had less than a week to work on our transduction project. (last Thursday until this coming Thursday). My project is using a phototransistor to control a DC motor. Like the brighter the light the more it spins, the less the more it slows or stops. I think my circuit is okay because the motor works, but the phototransistor does not respond to light or darkness. Even my professor couldn't figure out what was wrong but I assume that my coding is wonky. I bought the starter kit and combined the code from the Light Theremin and Motorized Pinwheel projects.
int sensorValue;
int sensorLow = 1023;
int sensorHigh = 0;
const int ledPin = 13;
const int motorPin = 9;
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
while (millis() < 5000) {
sensorValue = analogRead(A0);
if (sensorValue > sensorHigh) {
sensorHigh = sensorValue;
if (sensorValue < sensorLow) {
sensorLow = sensorValue;
digitalWrite(ledPin, LOW);
if (sensorValue == sensorLow) {
digitalWrite(motorPin, HIGH);
else {
digitalWrite(motorPin, LOW);
I have until Thursday (Oct 6) to get this to work. Please help if you can!
I think I have a picture of my circuit attached too.
it's difficult to see from your photo, but how is the sensor wired?
The sensor looks suspiciously like a LED - what is it really?
it's a phototransistor. It looks like an LED except it has a flat top. I used it when I first was trying Arduino and I made a theremin that used it to change the pitch of a piezo.
OK, that's answered half the questions.
Please use code tags when posting code. You can edit your post and
type
** **[code]** **
before your code
type
** **[/code]** **
after your code
OK, your setup() determines a low level. In loop you compare against that low level using '=='. Chances that the sensorValue is exactly that low level are not that big. You might want to use '<=' instead
  if (sensorValue <= sensorLow) {
You might also want to add a bit of play (hysteresis).
You can add some debugging to your code (use serial.println) and use serial monitor to display values that you have measured.
int sensorValue;
int sensorHigh = 0;
  Serial.print("sensorLow = "); Serial.println(sensorLow);
  Serial.print("sensorHigh = "); Serial.println(sensorHigh);
  Serial.print("sensorValue = "); Serial.println(sensorValue);
  if (sensorValue <= sensorLow + 5) {  <---------------------- added a bit of hysteresis
  else {
No idea about phototransistors so can't advise there; this is just the coding part.
