Light to control DC Motor
Please use code tags when posting code. You can edit your post and
type
** **[code]** **
before your code
type
** **[/code]** **
after your code
OK, your setup() determines a low level. In loop you compare against that low level using '=='. Chances that the sensorValue is exactly that low level are not that big. You might want to use '<=' instead
  sensorValue = analogRead(A0);
  if (sensorValue <= sensorLow) {
You might also want to add a bit of play (hysteresis).
You can add some debugging to your code (use serial.println) and use serial monitor to display values that you have measured.
int sensorValue;
int sensorLow = 1023;
int sensorHigh = 0;
const int ledPin = 13;
const int motorPin = 9;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  while (millis() < 5000) {
    if (sensorValue > sensorHigh) {
      sensorHigh = sensorValue;
    if (sensorValue < sensorLow) {
      sensorLow = sensorValue;
  Serial.print("sensorLow = "); Serial.println(sensorLow);
  Serial.print("sensorHigh = "); Serial.println(sensorHigh);
  digitalWrite(ledPin, LOW);
  Serial.print("sensorValue = "); Serial.println(sensorValue);
  if (sensorValue <= sensorLow + 5) {  <---------------------- added a bit of hysteresis
    digitalWrite(motorPin, HIGH);
  else {
    digitalWrite(motorPin, LOW);
No idea about phototransistors so can't advise there; this is just the coding part.
