Hi guys,
I am trying to light up two leds using a remote control. The - button for the green led and the + button for the red one. It all works fine but the leds toggle on and off everytime I press the related button. What I want is to have the leds lighted up as long as I press the button and to have them go off when I release the button.
This seems to be tricky for which I miss the experience yet.
Anyone of you to help?
I know that it can be done. Somewhere I have seen something similar but using a different and older RC library so that wasn't a big help for me.
Any help is appreciated. Below I have pasted a listing of the code.
Regards,
Marcel
/IR remote Example/
#include "IRremote.h"//include IRremote library to decode the IR signals
/Declare Constants/
int IRreceiver = 12; //pin connected to IR receiver
int ledRed = 13; //pin connected to anode of led
int ledGreen = 11; //pin connected to anode of led
/Declare objects/
IRrecv irrecv(IRreceiver);//create instance of 'IRrecv'
decode_results results;//create instance of 'decode_results'
/Setup/
Serial.begin(9600);//initialize Serial communication
Serial.println("IR signals decoded");
irrecv.enableIRIn(); //start the IR receiver
pinMode(ledRed, OUTPUT);//initialize the led as output pin
pinMode(ledGreen, OUTPUT);//initialize the led as output pin
/loop/
if (irrecv.decode(&results)) //check if it is received an IR signal
Serial.println(results.value, HEX);//print on Serial monitor the value received in hexadecimal.Read the value of the button that you want use and put it into the switch case
IRsignal();//call the function IRsignal()
irrecv.resume(); //receive the next value
delay(200);//wait 200 millisecond
void IRsignal() //takes action based on IR code received
int status_ledRed=0; //state of Red led
int status_ledGreen=0; //state of Green led
status_ledRed = digitalRead(ledRed); //read the status of ledRed
status_ledGreen = digitalRead(ledGreen); //read the status of ledGreen
switch(results.value) //check the IR signal received
case 0xFF906F: // Button code : +
if (status_ledRed==0){
Serial.println("Turn on Red Led "); //print on Serial monitor:"Turn on Red Led"
digitalWrite(ledRed, HIGH); //turn on Red led
status_ledRed=1;
Serial.print("Red Led ");
Serial.println(status_ledRed); //print the status of Red Led
Serial.print("Green Led ");
Serial.println(status_ledGreen); //print the status of Green Led
if (status_ledRed==1){
Serial.println("Turn off Red Led "); //print on Serial monitor:"Turn off Red Led"
digitalWrite(ledRed, LOW); //turn off Red led
status_ledRed=0;
Serial.println(status_ledRed); //print the status of led Red
case 0xFFA857: //Button code : -
if (status_ledGreen==0){
Serial.println("Turn on Green Led "); //print on Serial monitor:"Turn on Green Led"
digitalWrite(ledGreen, HIGH); //turn on Green led
status_ledGreen=1;
if (status_ledGreen==1){
Serial.println("Turn off Green Led "); //print on Serial monitor:"Turn off Green Led"
digitalWrite(ledGreen, LOW); //turn off Green led
status_ledGreen=0;
default:
Serial.println("Other button");
