Light-weight Encoder menu?
Hi All, before getting down to write my own, I thought I would ask here first.
Does anyone know of a light-weight menu system for a 4-line LCD + Encoder with button-switch?
I have found quite a few but just compiling the examples runs to about 55% of memory. They are quite extensive and comprehensive but I just need 12 line items to slide within the 4 LCD lines. Some have numeric data to roll through and some have Yes/No. e.g.
temp to set 50
pump on Y
door closed N
low warning 34
high warning 102
alarm set Y
Do those examples use the F() macro for prompt strings?
Designed for 1 and 2 line displays, so may not be what you are looking for: https://github.com/MajicDesigns/MD_Menu
marco_c: Designed for 1 and 2 line displays, so may not be what you are looking for:
Thanks, but does not seem lightweight. The single example will not run without the dependencies below. Which, by the way are not included with the GIt-Download and must be gathered and installed separately.
Not what I would call "quality" software when they do not include all the requirements to test, especially so since all are all written the same person wrote.
// External Dependencies // --------------------- // - MD_UISwitch library for digital and analog switches at https://github.com/MajicDesigns/MD_UISwitch // - MD_REncoder library for rotary encoder input at https://github.com/MajicDesigns/MD_REncoder // - MD_Parola library for LED matrix display at https://github.com/MajicDesigns/MD_Parola // - MD_MAX72XX library to support Parola library at https://github.com/MajicDesigns/MD_MAX72XX
Don’t confuse your convenience with the quality of the software.
You don’t need any of those if you write your own callback functions, but I suppose you did not read any of the documentation that is part of the download.
Good luck with your project.
