Observations: //*** suggestions
int ledPin=8; //*** replace with: static const byte ledPin = 8;
//*** constants should be declared as const; the compiler can
//*** generate better code
int buttonPin=2; //*** replace with: static const byte buttonPin = 2;
int buttonState=0 //*** There is no reeason to declare this as a global variable; make it a local
//*** Leave at least one blank line before function definitions. Makes the code more readable
pinMode(ledPin,OUTPUT);
pinMode(buttonPin,INPUT); //*** should be INPUT_PULLUP, button grounds pin
buttonState=analogRead(buttonPin); //***buttonPin is not an analog pin!
int buttonState = digitalRead(buttonPin); //*** This is the correct way to read a digital pin
//*** Note that since buttonState is only needed inside loop(), it should not be declared
//*** at any greater scope
if(buttonState==HIGH){ //*** If using INPUT_PULLUP, HIGH means button *not* pressed
//*** You did not specify the circuit, but thre correct circuit would be
//*** | o----------------| 2 |
//*** -| | Arduino | R1 LED
//*** | o-----+ | 3 8 |---/\/\/\/\/\---------|>|------- GND
//*** GND :
digitalWrite(ledPin,HIGH);
else{
digitalWrite(ledPin,LOW);
} // loop //*** I have found this convention to improve readability
//*** This whole loop contains unnecessary complexity. The entire body of loop() should be
digitalWrite(ledPin, !digitalRead(buttonPin));
You could also use a pulldown resistor, with the button connecting to +V, so LOW means "not pressed" and HIGH means "pressed", but pulldown resistors are uncommon, and INPUT_PULLUP saves you putting an explicit pullup resistor in place.
You can't give a software example like this without specifying the schematic of what it is getting as input and how the output is controlled.
The input to a pin must always be well-defined. That is, it can be HIGH or LOW, but it cannot be "unconnected". INPUT_PULLUP puts an ~50K pullup resistor connecting the pin to HIGH, and pushing the button sets it to LOW. If it is unconnected, you will see random behavior. And analogRead is "not defined" for a digital input pin, and thus is free to do anything, such as have a behavior indistinguishable from calling random().
Note that this works OK with an LED, but if you care about the button presses, you will have to "debounce" the button, because the button will produce more than one "pressed" signal and more than one "released" signal; you have to wait 5-10ms before trusting the button state. Google for "debounce" and study the code. Any form of delay() is usually considered a bad idea, so look for non-delayed debouncing. For complex code with real-time constraints, delay() can be fatal to correct response.
joe
