Lighting an LED when Temp is below 70
Hello all.
I am using a Grove starter kit plus. I have a temp sensor and the RGB Backlight display which is showing the room temp. That is working fine and I can see what the room temp is. I wanted to light an LED when the temp goes below 70 degrees. Later I want to hookup a relay to turn my boiler on and off based on room temp.
I am not able to make it work. I am pasting my code below. Am i missing something (which i am sure i am).? I left in my commented out code of what i tried before i tried the if statement.
Any help would be appreciated.
Thanks
Eddie
#include <Wire.h> //LDC libraries
#include "rgb_lcd.h"
rgb_lcd lcd; //Declare the LCD
const int pinTemp = A0; // pin of temperature sensor
const int pinLed = 3; // pin of led define here
//Set the color of LCD to red
const int colorR = 255;
const int colorG = 0;
const int colorB = 0;
float temperature;
int B=3975; // B value of the thermistor
float resistance;
pinMode(pinLed, OUTPUT); // set led OUTPUT
Serial.begin(9600); //set to read output on serial monitor
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.setRGB(colorR, colorG, colorB);
// Print a message to the LCD.
lcd.print("Room Temperature:");
int val = analogRead(pinTemp); // get analog value
resistance=(float)(1023-val)*10000/val; // get resistance
temperature=1/(log(resistance/10000)/B+1/298.15)-273.15; // calc temperature
temperature = (temperature * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
Serial.println(temperature);
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(temperature);
if (temperature < 70)
digitalWrite (pinLed = HIGH);
else (temperature > 70)
digitalWrite (pinLed = LOW);
for(int i=HIGH; temerature<70; i++)
analogWrite(pinLed, i);
delay(5);
delay(100);
for(int i=LOW; temerature>70; i--)
delay(100);
delay(1000); // delay 1s
Sorry I did not enter the code correctly. I am adding it again here.
Thanks
Eddie
float temperature;
float resistance;
    lcd.begin(16, 2);
      delay(5);
    delay(100);
      delay(100);
Please put your sketch in code tags. You can go back and edit the original post.
You don't need to check for both conditions <70 or >70 (though you have a dead point at exactly 70)
   if (temperature < 70.0)
You may find this Wikipedia entry on hysteresis useful, especially parts 3.1 and 3.2
Yes, I will look at it now. I also found many errors on my own. I fixed them. It still does not work though.
float temperature;
float resistance;
    lcd.begin(16, 2);
     digitalWrite (pinLed, HIGH);
     digitalWrite (pinLed, LOW);
What's this?
     digitalWrite (pinLed = HIGH);  // NO NO!
   else (temperature > 70)  // no!
     digitalWrite (pinLed = LOW);  // NO NO!
Perhaps you meant
or, much better:
  digitalWrite (pinLed, temperature < 70) ;  // true == HIGH, false == LOW
And the opposite condition to (temperature < 70) is (temperature >= 70), not
(temperature > 70)
I will give that a try. I saw that i made the first mistake of = instead of ,. I did fix that. I will try both styles. I like the last one though. Thank you for your help.
Eddie
