Lightning LED with an XBEE
Hello guys! Hope you're having a good day!
I am a student that has to do a project till the end of the year.
Tho my problem is that I've been asked to show that there is an existing connexion between two XBEEs by lightning a LED on the receiving part of the project.
I am new to XBees and bad in general with everything that's about codes with arduino montages etc..
I have configurated my XBees with XCTU, tho I have no idea about how to light a LED now.
I have S1 XBees. The part of the project that sends informations is a game controler with an Arduino Leonardo inside.
The receiving module is on an Arduino UNO with an XBEE shield and a Motor shield 2.0 from adafruit.
Please tell me if there's a code that I should use or test to light a LED on the receiving part of the project after the sending one asked to light up that LED.
Thank you soo much for reading!
Yes there is.
C'est le forum français ici...
Mince désolé j'étais pas sûr..
Etant donné qu'il y avait marqué "Subject" au lieu de sujet je me suis mis à écrire en anglais...
Auriez vous alors la solution s'il vous plaît? :frowning:
Vous avez essayé quoi jusqu'à présent?
Si vous savez échanger de l'info (plein de tutos dispos) alors rajouter un digitalWrite pour allumer la LED ce ne doit pas être hors de portée...
J'ai pris les examples dans la librairie XBee.
Du côté émetteur on a:
#include <XBee.h>
This example is for Series 1 XBee
Sends a TX16 or TX64 request with the value of analogRead(pin5) and checks the status response for success
Note: In my testing it took about 15 seconds for the XBee to start reporting success, so I've added a startup delay
XBee xbee = XBee();
unsigned long start = millis();
// allocate two bytes for to hold a 10-bit analog reading
uint8_t payload[] = { 0, 0 };
// with Series 1 you can use either 16-bit or 64-bit addressing
// 16-bit addressing: Enter address of remote XBee, typically the coordinator
Tx16Request tx = Tx16Request(0, payload, sizeof(payload));
// 64-bit addressing: This is the SH + SL address of remote XBee
//XBeeAddress64 addr64 = XBeeAddress64(0x0013a200, 0x4008b490);
// unless you have MY on the receiving radio set to FFFF, this will be received as a RX16 packet
//Tx64Request tx = Tx64Request(addr64, payload, sizeof(payload));
TxStatusResponse txStatus = TxStatusResponse();
int pin5 = 0;
int statusLed = 11;
int errorLed = 12;
void flashLed(int pin, int times, int wait) {
    for (int i = 0; i < times; i++) {
      digitalWrite(pin, HIGH);
      delay(wait);
      digitalWrite(pin, LOW);
      if (i + 1 < times) {
        delay(wait);
  pinMode(statusLed, OUTPUT);
  pinMode(errorLed, OUTPUT);
  Serial1.begin(9600);
  xbee.setSerial(Serial1);
   // start transmitting after a startup delay.  Note: this will rollover to 0 eventually so not best way to handle
    if (millis() - start > 15000) {
      // break down 10-bit reading into two bytes and place in payload
      pin5 = analogRead(5);
      payload[0] = pin5 >> 8 & 0xff;
      payload[1] = pin5 & 0xff;
      xbee.send(tx);
      // flash TX indicator
      flashLed(statusLed, 1, 100);
    // after sending a tx request, we expect a status response
    // wait up to 5 seconds for the status response
    if (xbee.readPacket(5000)) {
        // got a response!
        // should be a znet tx status
    	if (xbee.getResponse().getApiId() == TX_STATUS_RESPONSE) {
    	   xbee.getResponse().getTxStatusResponse(txStatus);
    	   // get the delivery status, the fifth byte
           if (txStatus.getStatus() == SUCCESS) {
            	// success.  time to celebrate
             	flashLed(statusLed, 5, 50);
            	// the remote XBee did not receive our packet. is it powered on?
             	flashLed(errorLed, 3, 500);
    } else if (xbee.getResponse().isError()) {
      //nss.print("Error reading packet.  Error code: ");
      //nss.println(xbee.getResponse().getErrorCode());
      // or flash error led
      // local XBee did not provide a timely TX Status Response.  Radio is not configured properly or connected
      flashLed(errorLed, 2, 50);
(J'ai fait attention d'ajouter un 1 au Seiral afin de convenir à l'arduino Leonardo.
Du côté récepteur on a:
#include <XBee.h>
This example is for Series 1 XBee (802.15.4)
Receives either a RX16 or RX64 packet and sets a PWM value based on packet data.
Error led is flashed if an unexpected packet is received
XBee xbee = XBee();
XBeeResponse response = XBeeResponse();
// create reusable response objects for responses we expect to handle
Rx16Response rx16 = Rx16Response();
Rx64Response rx64 = Rx64Response();
int statusLed = 11;
int errorLed = 12;
int dataLed = 10;
uint8_t option = 0;
uint8_t data = 0;
      delay(wait);
        delay(wait);
  pinMode(dataLed,  OUTPUT);
  // start serial
  xbee.setSerial(Serial);
  flashLed(statusLed, 3, 50);
// continuously reads packets, looking for RX16 or RX64
    xbee.readPacket();
    if (xbee.getResponse().isAvailable()) {
      // got something
      if (xbee.getResponse().getApiId() == RX_16_RESPONSE || xbee.getResponse().getApiId() == RX_64_RESPONSE) {
        // got a rx packet
        if (xbee.getResponse().getApiId() == RX_16_RESPONSE) {
                xbee.getResponse().getRx16Response(rx16);
        	option = rx16.getOption();
        	data = rx16.getData(0);
                xbee.getResponse().getRx64Response(rx64);
        	option = rx64.getOption();
        	data = rx64.getData(0);
        // TODO check option, rssi bytes
        flashLed(statusLed, 1, 10);
        // set dataLed PWM to value of the first byte in the data
        analogWrite(dataLed, data);
      	// not something we were expecting
        flashLed(errorLed, 1, 25);
C'est simplement les programmes de test que j'ai peu modifié. Help please!!
J'ai oublié d'ajouter que la LED doit être allumée suite à l'appui d'un bouton poussoir d'une manette de jeu sans fil ( Wirless_GamePad_V2.0__SKU_DFR0182_-DFRobot ) les pins associés au boutons poussoirs sont indiqués sur le site. Il y a une histoire du button state mais je ne sais vraiment pas comment faire, désolé, veuillez m'aider un tout petit peu :frowning:
