Lightning sensor AS3935 spi issue with sdcard IN ESP32, making interfere during writing data
Hi, team,
I'm building an lightning detection project using As3935 sensor, when i write sd card , it generate discturbance to signal ,sometimes it causes to showing as lighenign event by As3935 , making this sensor unreliable.
here my code :
#include <Wire.h>
#include "SparkFun_AS3935.h"
#define sdp 25  int i=0,sim=1;
#define INDOOR 0x12
#define OUTDOOR 0xE
#define LIGHTNING_INT 0x08
#define DISTURBER_INT 0x04
#define NOISE_INT 0x01
#include "SD.h"
// SPI
SparkFun_AS3935 lightning;
void initFS() {
  if (!SD.begin(25)) {
    Serial.println("An error has occurred while mounting SD"); }
  else {  Serial.println("SD mounted successfully");
// Interrupt pin for lightning detection
const int lightningInt =4;
// Chip select pin
int spiCS = 14;  // 14 in new v3 pcb
// Values for modifying the IC's settings. All of these values are set to their
// default values.
byte noiseFloor = 7;
byte watchDogVal = 9;
byte spike = 11;
byte lightningThresh = 1;
// This variable holds the number representing the lightning or non-lightning
// event issued by the lightning detector.
byte intVal = 0;
  // When lightning is detected the interrupt pin goes HIGH.
  pinMode(lightningInt, INPUT);
  pinMode(12, OUTPUT);
   pinMode(27, OUTPUT);
  Serial.println("AS3935 Franklin Lightning Detector");
  digitalWrite(27, HIGH);
  delay(1500);
    digitalWrite(27, LOW);
  SPI.begin(); // For SPI
  if( !lightning.beginSPI(spiCS) ) {
    Serial.println ("Lightning Detector did not start up, freezing!");
    while(1);
    Serial.println("Schmow-ZoW, Lightning Detector Ready!\n");
  lightning.setIndoorOutdoor(INDOOR);
  int enviVal = lightning.readIndoorOutdoor();
  Serial.print("Are we set for indoor or outdoor: ");
  if( enviVal == INDOOR )
    Serial.println("Indoor.");
  else if( enviVal == OUTDOOR )
    Serial.println("Outdoor.");
    Serial.println(enviVal, BIN);
  lightning.setNoiseLevel(noiseFloor);
  int noiseVal = lightning.readNoiseLevel();
  Serial.print("Noise Level is set at: ");
  Serial.println(noiseVal);
  lightning.watchdogThreshold(watchDogVal);
  int watchVal = lightning.readWatchdogThreshold();
  Serial.print("Watchdog Threshold is set to: ");
  Serial.println(watchVal);
  lightning.resetSettings();
  delay(2000);
  lightning.maskDisturber(false);
  int maskVal = lightning.readMaskDisturber();
  Serial.print("Are disturbers being masked: ");
  if (maskVal == 1)
  Serial.println("YES");
  else if (maskVal == 0)
  Serial.println("NO");
  lightning.spikeRejection(spike);
  int spikeVal = lightning.readSpikeRejection();
  Serial.print("Spike Rejection is set to: ");
  Serial.println(spikeVal);
  lightning.lightningThreshold(lightningThresh);
  uint8_t lightVal = lightning.readLightningThreshold();
  Serial.print("The number of strikes before interrupt is triggerd: ");
  Serial.println(lightVal);
   initFS();
   digitalWrite(spiCS, HIGH);
  digitalWrite(sdp, LOW);
  File conn = SD.open("/conn.csv");
  if (!conn) {
    Serial.println("File doens't exist");
    Serial.println("Creating file...");
    writeFile(SD, "/conn.csv", "TIME,SIM,BMP,LIGHT,BATTERY,SOLAR,RTC,SD,Mac,Imei\r\n");
  else {
    Serial.println("File already exists");
  conn.close();
  String dataString1 = "";
  dataString1 += String(sim);
  dataString1 += "\r\n";
  Serial.println(dataString1);
  appendFile(SD, "/conn.csv", dataString1.c_str());
  digitalWrite(sdp, HIGH);
  digitalWrite(spiCS, LOW);
  light =0;
  if(digitalRead(lightningInt) == HIGH){
    // Hardware has alerted us to an event, now we read the interrupt register
    // to see exactly what it is.
    intVal = lightning.readInterruptReg();
    if(intVal == NOISE_INT){
      Serial.println("Noise.");
        digitalWrite(12, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(100);                       // wait for a second
  digitalWrite(12, LOW);
    else if(intVal == DISTURBER_INT){
      Serial.println("Disturber.");
  delay(500);                       // wait for a second
  digitalWrite(12, LOW);    // turn the LED off by making the voltage LOW
//  delay(200);
    else if(intVal == LIGHTNING_INT){
      i++;
      light=1;
      Serial.println("Lightning Strike Detected!");
      // Lightning! Now how far away is it? Distance estimation takes into
      // account previously seen events.
      byte distance = lightning.distanceToStorm();
      Serial.print("Approximately: ");
      Serial.print(distance);
      Serial.println("km away!");
  Serial.println(i);
      // "Lightning Energy" and I do place into quotes intentionally, is a pure
      // number that does not have any physical meaning.
      long lightEnergy = lightning.lightningEnergy();
      Serial.print("Lightning Energy: ");
      Serial.println(lightEnergy);
  //     digitalWrite(12, HIGH);
   //      digitalWrite(27, HIGH); // turn the LED on (HIGH is the voltage level)
  String dataString2 = "";
   dataString2 += String(light);
        dataString2 += "\r\n";
        Serial.println(dataString2);
       appendFile(SD, "/conn.csv", dataString2.c_str());
Of course, Append & write functions are simple taken from common example of sd library.
Please someone if you could , check if any pin already low in library of AS3935 , where i need to modification to my chip select possible to control. (as i understand, the CS pin only making issue as both are SPI protocol interfering somewhere due to two library.)
Thanks in advance !
Please don't yell
Please do not write in ALL CAPS - like you're yelling
sorry it was by mistake by keyboard caps lock, I was unaware of this rule of the forum.
I fixed the problem myself,
Thanks you guys!
