Hello,
I am building a cake topper for my wedding and I just got some Adafruit Neopixel rings to do some lighting effects but Im having a problem getting the lights to work in my program. I have the lights working in a different sketch but when I try to add it I keep getting function-definition is not allowed here before "{" token errors. Im not sure why since it is set up exactly like the file that works. Here is the code that works
#define PIN 53
// Parameter 1 = 24
// Parameter 2 = PIN
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(36, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
strip.begin();
strip.show(); // Initialize all pixels to 'off'
delay(5000);
rainbow(150);
// rainbowCycle(20);
// theaterChaseRainbow(50);
// Fill the dots one after the other with a color
//void colorWipe(uint32_t c, uint8_t wait) {
// for(uint16_t i=0; i<strip.numPixels(); i++) {
// strip.setPixelColor(i, c);
// strip.show();
// delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
and this is the code I have so far that will not work.
//MUSIC--------------------------------------------
// include SPI, MP3 and SD libraries
#include <SPI.h>
#include <Adafruit_VS1053.h>
#include <SD.h>
// These are the pins used for the breakout example
#define BREAKOUT_RESET 9 // VS1053 reset pin (output)
#define BREAKOUT_CS 10 // VS1053 chip select pin (output)
#define BREAKOUT_DCS 8 // VS1053 Data/command select pin (output)
// These are the pins used for the music maker shield
#define SHIELD_RESET -1 // VS1053 reset pin (unused!)
#define SHIELD_CS 7 // VS1053 chip select pin (output)
#define SHIELD_DCS 6 // VS1053 Data/command select pin (output)
// These are common pins between breakout and shield
#define CARDCS 4 // Card chip select pin
// DREQ should be an Int pin, see attachInterrupt() - Arduino Reference
#define DREQ 3 // VS1053 Data request, ideally an Interrupt pin
Adafruit_VS1053_FilePlayer musicPlayer =
// create breakout-example object!
//Adafruit_VS1053_FilePlayer(BREAKOUT_RESET, BREAKOUT_CS, BREAKOUT_DCS, DREQ, CARDCS);
// create shield-example object!
Adafruit_VS1053_FilePlayer(SHIELD_RESET, SHIELD_CS, SHIELD_DCS, DREQ, CARDCS);
//Start Button-----------------------------------------
int inPin = 41; // choose the input pin (for a pushbutton)
int val = 0; // variable for reading the pin status
//Interior Light----------------------------------------
int led = 28; // the pin that the Interior LED is attached to
//Motor Control------------------------------------------
int motorPin = 22;
//Sillohette Lights:-----------------------------------
#define PIN 53
//Start Button Input :----------------------------------
pinMode(inPin, INPUT); // declare pushbutton as input
//Interior LED Setup:-----------------------------------
pinMode(led, OUTPUT);
//Motor Control:--------------------------------------
pinMode(motorPin, OUTPUT);
//MUSIC----------------------------------------------
Serial.println("Adafruit VS1053 Library Test");
// initialise the music player
if (! musicPlayer.begin()) { // initialise the music player
Serial.println(F("Couldn't find VS1053, do you have the right pins defined?"));
while (1);
Serial.println(F("VS1053 found"));
if (!SD.begin(CARDCS)) {
Serial.println(F("SD failed, or not present"));
while (1); // don't do anything more
Serial.println("SD OK!");
// list files
printDirectory(SD.open("/"), 0);
// Set volume for left, right channels. lower numbers == louder volume!
musicPlayer.setVolume(1,1);
if (! musicPlayer.useInterrupt(VS1053_FILEPLAYER_PIN_INT))
Serial.println(F("DREQ pin is not an interrupt pin"));
strip.begin();
//Interior LED
digitalWrite(led, 255);
//Start Button Execution
val = digitalRead(inPin); // read input value
if (val > 0) { // check if the input is HIGH (button released)
digitalWrite(motorPin, HIGH);
// Alternately, we can just play an entire file at once
// This doesn't happen in the background, instead, the entire
// file is played and the program will continue when it's done!
musicPlayer.playFullFile("WedTop1.ogg");
// Start playing a file, then we can do stuff while waiting for it to finish
if (! musicPlayer.startPlayingFile("WedTop1.mp3")) {
Serial.println("Could not open file WedTop1.mp3");
while (1);
Serial.println(F("Started playing"));
while (musicPlayer.playingMusic) {
// file is now playing in the 'background' so now's a good time
// to do something else like handling LEDs or buttons ![]()
Serial.print(".");
delay(54000);
rainbow(150);
void rainbow(uint8_t wait){
uint16_t i, j;
strip.show();
delay(wait);
uint16_t i, j;
strip.show();
delay(wait);
if(WheelPos < 85) {
WheelPos -= 85;
WheelPos -= 170;
/// File listing helper
void printDirectory(File dir, int numTabs) {
while(true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
//Serial.println("nomorefiles");
for (uint8_t i=0; i<numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs+1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
can anyone give me a hand on this one? Thanks!
