I'm having an issue with programming some addressable RGB LED's. I've created a very simple program, simple lights up a single LED in the strip. The problem I'm having is that , while the LED I've instructed to turn on, is coming on, all the other LEDS in the strip are flashing.
I thought I may have a soldering issue, but I checked this on a seperate strip and same issue is happening. Any help would be appreciated.
Your loop is switching the leds on every time it loops - I wonder if that’s the problem? Try adding a delay in the loop to see if that changes the flicker frequency.
-- I tried several different led strips same problem
I then changed the power supply - I wired power and ground directly to the Arduino Board and it works fine.
The question is why? I have a great big power supply (5V 60Amp Tanbaby) and I checked the voltage going to the led strip and it was getting the right voltage.
Any ideas? I do want to use the power supply for bigger lighting projects.
Very good question, and the answer is shrouded in mystery. The mystery of your actual wiring, the actual other power supplies you tried and how you connected those, the actual sketch you're running now, etc.
