Hello Fellas.
This is my first post. I've been doing Arduino for a couple of years now, currently doing a small personal project where I'm using an L29110S Motor controller and an arduino Uno to simulate a Scale Aircraft starting up engines (2 of them). That part I have completed. However, I ran into some issues I can't get my head around, and I need some serious pointers and guidance. LIke I said I know my way around Arduino but this seems to be out of my reach.
The issue is that, besides the Motors, the aircaft has 5 more lights. It should have 3 Nav Lights, which are steady. Easy, just hook onto the 5V line. However, there are 2 more blinking beacon lights - each on a different timer - one above, and one below the aircraft. They indicate the engines are either powered or wil be powered soon.
The Aircraft only has 5 contact points to the ground - 2 tires on each main landing gear, and one on the nose gear. I'm not planning on housing any electronics inside the aircraft. Since the L29110S to control speed requires 4 pins each, at first I was faced with using maybe 6 points (and wasn't sure where I was going to put them). Then I figured I could use both A1-A and B1-B pins in the same pin - and it worked. Then I figured I could do better, and save a contact point if I use them as ground. It also worked. So far so good. The problem started when I tried to add the beacon lights.
Question No. 1
I decided "screw it, hook off the 5V line just like the nav lights and just put a 555 / 2N3409 circuit on them and just mess around with the Capacitors to archieve the proper on/off sequence."
Aaaaand that works only when the engines are NOT running. I'm thinking since the motors are sharing the A1-A and B1-B as grounds, I'm asuming that's messing with the Circuit. So,is it possible make arduino have different grounds? or should I connect them to a common, battery ground and have arduino Feed that? I am definetly lost here.
Oh btw the final project will be 5v throughout fed from the Arduino which will in turn be fed out of a 9V wall ac/dc converter.
Question 2:
Since the Code is primarily focused on turning the engines, any regular, determined on/off on one of the beacons will either occur before or after the engines are done. (basically the same problem as question 1, entirely different approach). Is there a way to have a different, separate timer working independantly and parallel to the main loop??
This would be the plan b, since this wouild require 2 more contact points. I MAY just end up making them simultaneous and use 1 contact point / pin.
Or fix the Ground issue. IDK. Whichever Is more feasable. Thank you for the pointers people.
