Lights won't stay on (Arduino > DMX Dimmer)
Hello everyone,
When we upload this piece of code:
#include "pins_arduino.h"
int sig = 11; // signal
int channel [512]; // DMX frame buffer
int wait = 1000L; // How long should the light be on? In milliseconds (1ms = 0.001s)
pinMode(sig, OUTPUT);
lights();
void lights()
// 0700 hrs
setChannel(1,150); // Adjust lightintensity; (A,B)
setChannel(2,255); // A = channel [1=Nikki 2=Roger 3=Michiel]
setChannel(3,100); // B = Light intensity [100=depressed, 130=moody, 150=normal, 180=happy, 255=superhappy]
sendDMXframe(); // Fill buffer
delay(wait); // Turn on the lights (time = 'wait').
// 0800 hrs
setChannel(1,200); // Adjust lightintensity; (A,B)
setChannel(2,200); // A = channel [1=Nikki 2=Roger 3=Michiel]
setChannel(3,150); // B = Light intensity [100=depressed, 130=moody, 150=normal, 180=happy, 255=superhappy]
// 0900 hrs
setChannel(1,255); // Adjust lightintensity; (A,B)
setChannel(2,150); // A = channel [1=Nikki 2=Roger 3=Michiel]
Our three lights change every second.
But when we raise the delay to 10000ms:
int wait = 10000L; // How long should the light be on? In milliseconds
The light go out after aprox. 3 seconds.
This delay however does work! After 10 seconds it switches to the second set of light intensity values.
Does anyone know why this happens and how we can fix this?
We are working with an Arduino Duemilanova, a 4 channel power DMX Dimmer pack and we are programming in an OSX environment.
If you need more info regarding this issue let me know! :slight_smile:
int wait = 1000L;
using the L implies that 1000 is a long. longs are 32 bit on Arduino, ints are 16 bit. delay() expects an unsigned long. see http://www.arduino.cc/en/Reference/Delay
That's the only thing I see that could affect timing ...
Thanks for your reply Rob.
We have used both 1000L as well as 1000 as values for our 'int wait'.
We changed the code to:
int sig = 12; // signal
unsigned long wait = 10000; // How long should the light be on? In milliseconds (1ms = 0.001s)
lights();
void lights()
// 0700 hrs
// 0800 hrs
setChannel(1,190); // Adjust lightintensity; (A,B)
setChannel(2,190); // A = channel [1=Nikki 2=Roger 3=Michiel]
setChannel(3,190); // B = Light intensity [100=depressed, 130=moody, 150=normal, 180=happy, 255=superhappy]
// 0900 hrs
setChannel(3,255); // B = Light intensity [100=depressed, 130=moody, 150=normal, 180=happy, 255=superhappy]
Unfortunately, the problem persists.
