Right ive got the example code to work, however I want to change it so that it toggles on and off for every button press as apposed to every 4 in the example. Ive tried changing the '4' in the code below to 1 or even 0 however unsure how to change it to get the result im after? Any help please?
// turns on the LED every four button pushes by
// checking the modulo of the button push counter.
// the modulo function gives you the remainder of
// the division of two numbers:
if (buttonPushCounter % 4 == 0) {
digitalWrite(ledPin, HIGH);
digitalWrite(ledPin, LOW);
Code so far for LS2 (Light saber Project):
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time,
but you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
- pushbutton attached to pin 2 from +5V
- 10K resistor attached to pin 2 from ground
- LED attached from pin 13 to ground (or use the built-in LED on
most Arduino boards)
created 27 Sep 2005
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
ATMEGA328P Pinout
Red D 09
Green D 10
Blue D 11
LS2 main button (buttonPin) D 02
RX (from audio board) D 01
TX (from audio board) D 00
// this constant won't change:
const int buttonPin = 2; // the pin that the pushbutton is attached to
const int ledPin = 13; // the pin that the LED is attached to
const int red = 9; // green led star
const int green = 10; // green led star
const int blue = 11; // green led star
// Variables will change:
int buttonPushCounter = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
// initialize serial communication:
digitalWrite(red, LOW);
digitalWrite(blue, LOW);
digitalWrite(green, LOW);
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
digitalWrite(green, HIGH);
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
digitalWrite(green,LOW);
// Delay a little bit to avoid bouncing
delay(100);
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
