Introduction
Hi everyone,
This is my first time posting on the Arduino forum, and I hope my contribution will be helpful to others. I wanted to share my solution to a problem I encountered, along with some insights that were particularly useful to me.
I was working with the LilyGo TTGO USB ATMEGA32U4 and accidentally uploaded a sketch incorrectly using the Arduino IDE. This caused the device to become "unrecognizable" in the Windows Device Manager, showing up as "Unknown USB Device (Device Descriptor Request Failed)" or something similar.
In my case, I managed to "brick" the device by first selecting the wrong board/programmer in the Arduino IDE and then uploading a sketch. So this resemble a lot this post.
I’m writing this post to describe a final step that helped my PC recognize the microcontroller again.
The solution discussed in the post above is this one. In this post though, they doesn't show the exact same board, but others with the same ATMEGA32U4 microcontroller.
Initial situation
Initially, I was able to use the device normally after setting it up with the Arduino IDE. However, after selecting a random board/programmer and attempting to upload a sketch, the device became undetectable by the Windows Device Manager. It showed up as Unknown USB Device (Device Descriptor Request Failed) with error code 43 in the device details.
Solution
After trying various driver-related fixes in Windows to no avail, I realized that the issue was with the microcontroller's program, which was interfering with the PC's USB detection.
- Dismantling the Microcontroller: I used a pair of pliers to extract the metal case containing the controller from the outer case. I then used a screwdriver to carefully lift the controller from the bottom to detach the adhesive tape and push it out. Be gentle to avoid damaging the board.
- Resetting the Microcontroller: Once the controller was out, I connected it to my PC again. Then, using a wire, I shorted the ISCP pins GND and RST together to put the device in reset mode. Here’s the pinout of the board (props to the guy that mapped them).
- Uploading the Sketch: After resetting, I opened the Arduino IDE, navigated to the "EEPROM" examples, and selected the "eeprom_clear" sketch. I shorted again the pins RESET and GND together and quickly uploaded the sketch.
After following these steps, my board was detected as a COM port in the Device Manager again, and everything worked fine for me.
I hope this explanation wasn't too long, and if anyone has more insights on this topic, please feel free to share your knowledge!
Outro
I am writing this post few days after the problem has been solved using this exact method, sorry if everything is not technically precise I am slightly tired writing this.
I didn't replicate the problem multiple times because I didn't want to open it again and risk to damage the board, so this is what I managed to collect.
I am not sure about the eeprom_clear sketch and why it worked when others didn't, I tried other uploads but this one did the job.
