I cant get the Volos project to work, screen is black. Im using his code: ¨
"error" output message:
Sketch uses 228881 bytes (17%) of program storage space. Maximum is 1310720 bytes.
Global variables use 19152 bytes (5%) of dynamic memory, leaving 308528 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM4
Connecting...
Chip is ESP32-S3 (revision v0.1)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 68:b6:b3:21:ba:e8
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 921600
Changed.
Configuring flash size...
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00047fff...
Compressed 15040 bytes to 10331...
Writing at 0x00000000... (100 %)
Wrote 15040 bytes (10331 compressed) at 0x00000000 in 0.4 seconds (effective 330.7 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.1 seconds (effective 307.9 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 460.9 kbit/s)...
Compressed 229248 bytes to 127917...
Writing at 0x00010000... (12 %)
Writing at 0x0001cff4... (25 %)
Writing at 0x000228d0... (37 %)
Writing at 0x00027bee... (50 %)
Writing at 0x0002d19d... (62 %)
Writing at 0x000339f2... (75 %)
Writing at 0x0003dbc5... (87 %)
Writing at 0x00043339... (100 %)
Wrote 229248 bytes (127917 compressed) at 0x00010000 in 2.8 seconds (effective 648.0 kbit/s)...
Leaving...
Hard resetting via RTS pin.
#include "TFT_eSPI.h"
"install.h"
TFT_eSPI tft= TFT_eSPI();
TFT_eSprite sprite = TFT_eSprite(&tft);
tft.init();
tft.setRotation(1);
tft.setSwapBytes(true);
tft.fillScreen(TFT_WHITE);
tft.pushImage(106,0,214,170,install);
Serial.begin 921600
sprite.createSprite(146,170);
sprite.setTextColor(TFT_BLACK,TFT_WHITE);
sprite.setTextDatum(4);
//progress bar variables
int progress=0;
int w=120;
int h=18;
int x=12;
int y=90;
int blocks=0;
sprite.fillSprite(TFT_WHITE);
sprite.setFreeFont(&Orbitron_Light_24);
sprite.drawString("Progress:",75,16);
sprite.setFreeFont(&Orbitron_Light_32);
sprite.drawString(String(progress)+"%",75,54);
progress++;
if(progress==101)
progress=0;
blocks =progress/5;
sprite.drawRoundRect(x,y,w,h,3,TFT_BLACK);
for(int i=0;i<blocks;i++)
sprite.fillRect(i*5+(x+2)+(i*1),y+4,5,10,TFT_BLACK);
sprite.drawRect(10,124,60,22,TFT_BLACK);
sprite.drawRect(76,124,60,22,TFT_BLACK);
sprite.drawString("OK",40,134,2);
sprite.drawString("CANCEL",106,134,2);
sprite.setTextFont(0);
sprite.drawString("Installation almost done!!",80,160);
sprite.pushSprite(0,0);
delay(60);
#if defined(__AVR__)
#elif defined(__PIC32MX__)
#define PROGMEM
#elif defined(__arm__)
#define PROGMEM
#endif
const unsigned short install[36380] PROGMEM={
0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, 0xFFFF, // 0x0010 (16) pixels
ive tried this for troubleshooting: (copy paste from stack overflow)
Make sure that your serial monitor's baud rate matches the value used by Serial.begin
in your code. The top ESP32/ESP8266 example on Google uses 115200 whereas most people have their serial monitor set to 9600 because it's a common Arduino sketch value. This mismatch is the most common reason for people Googling this issue.
For other connection issues, such as COM connection issues, try these steps:
- Press the little "Reset" button (or "RST") on your board.
- Unplug the board's USB cable.
- Unplug anything from the TX/RX pins.
- Close all Arduino IDE windows including the serial monitor.
- Plug the USB cable back in and wait a few seconds.
- Reopen the Arduino window and choose the correct port under Tools > Port. If you see multiple unlabeled COM ports, you can use the "Get Board Info" option or simple trial and error to figure out the right port.
- Open the serial monitor and make sure the baud rate matches the one found in your code.
- Upload the sketch.
- If the upload fails, wait a few seconds and try it a second time.
Any help is much appreciated, let me know if more information is needed
