Lilygo TTGO T-display not working with TFT_eSPI
I'm trying to use a Lilygo TTGO T-display v.1.1 connected to I2C temp and hum sensors (BME280 and SHT3x) and a RTC DS3231 ( since WiFi isn't available where the device is supposed to work) in order to create a datalogger (already working with OLED and E-ink displays) but while one month ago I succeeded in this project, a couple of days ago when I picked up the project again without having made any changes to the HW (it's on breadboard) I've encountered a strange behaviour (at list for me, a newbie)
I followed the suggestions of this tutorial https://www.youtube.com/watch?v=WFVjsxFMbSM&t=0s where this board is identified in Arduino IDE as TTGO LoRa32 with TFT_eSPI User_Setup_Select.h defined as <User_Setups/Setup25_TTGO_T_Display.h>
I'm using Arduino IDE 2.2.1 and W11 and in order to upload the code I have to press the GPIO0 button when in serial monitor appears “Connecting….”
However, now the board enters into an endless loop and the screen is blank
I tried also to upload the example TFT.clock.ino from TFT_eSPI library and also a very simple sketch such as the following one
#include <TFT_eSPI.h>
#include<SPI.h>
TFT_eSPI tft = TFT_eSPI();
  tft.init();
  tft.fillScreen(TFT_RED);
but I always get the same error and this happens also if I define the board as ESP32 Dev Module
On the contrary, if I define the board as ESP32Dev AND I try another example which includes the Adafruit_7789 library but NOT the TFT_eSPI the board works fine
 //TTGO T-Display ST7789 OLED based on Adafruit example
//  https://github.com/adafruit/Adafruit-ST7735-Library/blob/master/examples/graphicstest/graphicstest.ino
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
// pinouts from https://github.com/Xinyuan-LilyGO/TTGO-T-Display
#define TFT_MOSI 19
#define TFT_SCLK 18
#define TFT_CS 5
#define TFT_DC 16
#define TFT_RST 23
#define TFT_BL 4
// constructor for data object named tft
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
void setup(void) {
  Serial.begin(9600); Serial.print(F("Hello! ST77xx TFT Test"));
  pinMode(TFT_BL, OUTPUT);      // TTGO T-Display enable Backlight pin 4
  digitalWrite(TFT_BL, HIGH);   // T-Display turn on Backlight
  tft.init(135, 240);           // Initialize ST7789 240x135
  Serial.println(F("Initialized"));
  uint16_t time = millis();
  tft.fillScreen(ST77XX_BLACK);
  time = millis() - time;
  Serial.println(time, DEC);
  // large block of text
  testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
  // tft print function!
  tftPrintTest();
  delay(4000);
  // a single pixel
  tft.drawPixel(tft.width() / 2, tft.height() / 2, ST77XX_GREEN);
  // line draw test
  testlines(ST77XX_YELLOW);
  // optimized lines
  testfastlines(ST77XX_RED, ST77XX_BLUE);
  testdrawrects(ST77XX_GREEN);
  testfillrects(ST77XX_YELLOW, ST77XX_MAGENTA);
  testfillcircles(10, ST77XX_BLUE);
  testdrawcircles(10, ST77XX_WHITE);
  testroundrects();
  testtriangles();
  mediabuttons();
  Serial.println("repeat");
  //  tft.invertDisplay(true);
  //  delay(500);
  //  tft.invertDisplay(false);
  //  delay(500);
void testlines(uint16_t color) {
  for (int16_t x = 0; x < tft.width(); x += 6) {
    tft.drawLine(0, 0, x, tft.height() - 1, color);
    delay(0);
  for (int16_t y = 0; y < tft.height(); y += 6) {
    tft.drawLine(0, 0, tft.width() - 1, y, color);
    delay(0);
    tft.drawLine(tft.width() - 1, 0, x, tft.height() - 1, color);
    delay(0);
    tft.drawLine(tft.width() - 1, 0, 0, y, color);
    delay(0);
    tft.drawLine(0, tft.height() - 1, x, 0, color);
    delay(0);
    tft.drawLine(0, tft.height() - 1, tft.width() - 1, y, color);
    delay(0);
    tft.drawLine(tft.width() - 1, tft.height() - 1, x, 0, color);
    delay(0);
    tft.drawLine(tft.width() - 1, tft.height() - 1, 0, y, color);
    delay(0);
void testdrawtext(char *text, uint16_t color) {
  tft.setCursor(0, 0);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
  for (int16_t y = 0; y < tft.height(); y += 5) {
    tft.drawFastHLine(0, y, tft.width(), color1);
  for (int16_t x = 0; x < tft.width(); x += 5) {
    tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
    tft.drawRect(tft.width() / 2 - x / 2, tft.height() / 2 - x / 2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
  for (int16_t x = tft.width() - 1; x > 6; x -= 6) {
    tft.fillRect(tft.width() / 2 - x / 2, tft.height() / 2 - x / 2 , x, x, color1);
    tft.drawRect(tft.width() / 2 - x / 2, tft.height() / 2 - x / 2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (int16_t x = radius; x < tft.width(); x += radius * 2) {
    for (int16_t y = radius; y < tft.height(); y += radius * 2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x = 0; x < tft.width() + radius; x += radius * 2) {
    for (int16_t y = 0; y < tft.height() + radius; y += radius * 2) {
      tft.drawCircle(x, y, radius, color);
void testtriangles() {
  uint16_t color = 0xF800;
  int t;
  int w = tft.width() / 2;
  int x = tft.height() - 1;
  int y = 0;
  int z = tft.width();
  for (t = 0 ; t <= 15; t++) {
    tft.drawTriangle(w, y, y, x, z, x, color);
    x -= 4;
    y += 4;
    z -= 4;
    color += 100;
void testroundrects() {
  uint16_t color = 100;
  int i;
  int t;
  for (t = 0 ; t <= 4; t += 1) {
    int x = 0;
    int y = 0;
    int w = tft.width() - 2;
    int h = tft.height() - 2;
    for (i = 0 ; i <= 16; i += 1) {
      tft.drawRoundRect(x, y, w, h, 5, color);
      x += 2;
      y += 3;
      w -= 4;
      h -= 6;
      color += 1100;
    color += 100;
void tftPrintTest() {
  tft.setTextWrap(false);
  tft.setCursor(0, 30);
  tft.setTextColor(ST77XX_RED);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ST77XX_YELLOW);
  tft.setTextSize(2);
  tft.setTextColor(ST77XX_GREEN);
  tft.setTextSize(3);
  tft.setTextColor(ST77XX_BLUE);
  tft.setTextSize(4);
  tft.print(1234.567);
  delay(1500);
  tft.setTextColor(ST77XX_WHITE);
  tft.setTextSize(0);
  tft.setTextSize(1);
  float p = 3.1415926;    // do not delete
  tft.print(p, 6);
  tft.println(" Want pi?");
  tft.println(" ");
  tft.print(8675309, HEX); // print 8,675,309 out in HEX!
  tft.println(" Print HEX!");
  tft.println(" ");
  tft.println("Sketch has been");
  tft.println("running for: ");
  tft.setTextColor(ST77XX_MAGENTA);
  tft.print(millis() / 1000);
  tft.print(" seconds.");
void mediabuttons() {
  // play
  tft.fillRoundRect(25, 10, 78, 60, 8, ST77XX_WHITE);
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_RED);
  // pause
  tft.fillRoundRect(25, 90, 78, 60, 8, ST77XX_WHITE);
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_GREEN);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_GREEN);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_BLUE);
  delay(50);
  // pause color
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_RED);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_RED);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_GREEN);
Sorry for the maybe trivial question but I'm a newbie and I was not able to find info on this strange behaviour.
Furthermore I'd like to use also for this board the Bodmer's TFT_eSPI library since I've already used it for ILI9341 and ST7735.
Thanks in advance for your help
In TFT_eSPI you need to specify your module/display model. To do that, edit the file User_Setup_Select.h, using Notepad or another flat-file editor. It's in the top level of the Library, so directly in the TFT_eSPI folder. For the TTGO_T_Display, in the list of the #include <User_Setups, make sure only the one with "Setup25" in it is not commented (no //). It specifies the <TTGO_T_Display.h>. All others need to be/remain commented out.
Good luck!
do you have a link to the TTGO LoRa32 board you are using?
e.g. is it ttgo-lora32-sx1276-OLED
if not upload a photo?
maybe worth trying Tools>Board Heltec WiFi LoRa 32 (V2)
Thanks for your suggestions.
I must confess that I abandoned that board and has been using other boards with E-INK display; furthermore I started studying more seriously Python in order to use it to code my ESPs.
Since I'm an old newbie (almost 74,) with a completely different background ( head and neck and ear surgeon) you can easily understand how slow is this process for me.
However I keep on working. In the following days I'll try to use again this board and I'll let you know what will happen. Thanks again for your help. Have a nice week
any particular reason to select Python
microcontrollers are usually programmed using C/C++
good observation.
However i toof this decision for two reasons : one practical , with micropython I succeded in making an ESP with integrated OLED to work as a datalogger with RTC and temp/hum sensors after several unsuccesfull attempts with C,C++ (due to my limits); the second is related to my limited time horizon due to my age. I thought that starting with an easier to learn language maybe would be better... Wll see...
sounds like you are making good progress
so long as you use powerful modern microcontrollers with plenty of flash and SRAM such as ESP32, RPi pico RP2040, etc MicroPython is an option
Hi
Thanks for your encouraging words
Have a nice day
Bruno
