Lilypad Cannot work under the latest version of arduino IDE.
After I plugin my lilypad board on Yosemite 10.10.4, and open the latest version of Arduino IDE(1.6.5), the tty-usbserial-XXX serial port cannot be found, there are only ports like cu-XXXX.
But I can see these entries in /dev directory:
/dev/cu.usbserial-AI02TT3P
/dev/tty.usbserial-AI02TT3P
So, The settings of my IDE must be:
Board: Lilypad arduino
Processor: ATmega328
Port: /dev/cu.usbserial-AI02TT3P
Programmer: AVRISP mkII
and I pressed down the upload button, then got the following issues:
Sketch uses 450 bytes (1%) of program storage space. Maximum is 30,720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
The problem has block me for a few days, I am looking for someone's help. Thanks a lot!
