I'm using windows Vista, and version 11 . I just received this from sparksfun today, I've tried resetting the board but with no luck .
how are you connecting the board to your computer?
what happens when you press the reset button on the lilypad? do you get 3 quick blinks?
I'm connecting it through Lilypad USB , when I press the reset button I get 3 really really quick blinks
Unfortunately, the error message you’re getting is the most common & uninformative one… the problem could really be anything. First things to check are: are you sure you’ve selected the correct serial port? are you sure the USB-serial drivers are installed correctly? Are you clicking the reset button on the lilypad just before you click the Upload button each time?
thanx this worked
