Upon plugging it into my Mac for the first time (via a micro USB cable > USB to USB C adapter/dongle), the light under "STAT" started a blinking and a subtle but high-pitched whining sound began. This doesn't seem right to me, because the sound instantly gave me a headache, and the UNO board I have doesn't do that. I'm attaching a video here: IMG_7419.MOV - Google Drive
Does this mean the board is defective, or maybe it's the connection to my computer? I'm also getting an error message trying to upload the blink sketch to it via the Arduino IDE. Any help/guidance would be much appreciated, thanks!
I saw that one, but their solution was for Windows so I wanted to see if any Mac users might be having the same issue. Sketches are uploading fine now to my LilyPad, it's just the noise I'm having trouble with.
Yeah, my Mac only has USB-C ports. I just tried it on a PC (which has a USB port, no dongle needed) with the Windows IDE and it still emits the screeching noise.
I'll try it on a portable charger this week and see if that works, thank you for the suggestion!
Looks like there's supposed to be a 30ohm ferrite bead and a 1uF bypass cap after the bead between VCC1 and the other three VCC inputs. There also appears to be no regulator. If I'm looking at the right schematic. I'm just a well-seeded amateur, but I believe this will make your wire resonate at a frequency determined by the chip speed and the wire length, though I don't know how to calculate it.
I think I read an ARRL article about this being done intentionally to play anchors away on an AM radio, but it's been 20 years.
