Limb movement to control motor
Any ideas for a simple way to sense whether a baby is kicking its leg without disrupting or limiting the baby's movement? To not disrupt infant movement, the sensor must either be lightweight or something that doesn't touch the baby - like a beam breaker.
Defining a kick can be complicated, especially for young infants. We have a motion tracking system we will use to study infant kicking in detail post facto, but I need to make a system to control the real-time feedback the infant receives from its own movement. The main objective here is to create some object (a mobile hanging over a crib) that can be moved easily by an infant, but that will quickly go back to rest when the infant stops kicking. The more frequent or more intense the infant kicks, the more the mobile moves. The mobile could be controlled by a motor, but I can also easily connect the infant to the mobile mechanically via a string (see video below for example). This solves the problem of defining a kick and kick intensity, but I'd still need to be able to sense lack of infant foot motion and use that lack of motion to terminate mobile movement. The mobile needs to brake when the infant stops kicking. And ideally, I'd like to be able to vary the force of the brakes.
Exactly how long of a pause in kicking is considered a pause? This question is probably going to be answered through pilot testing, but I remember one related study that defined it as 3 seconds.
To give you some context, here's a video of the classical setup for this type of study: Huck vs. Mobile - YouTube
(There's way too much freedom of movement for the mobile in this video. We want to have a tight link between infant immobility and mobile immobility. I tried using a simple helium balloon instead of a mobile, but the MoCap system gets screwed up from the glare off of the balloon.)
TIA!
I don't see a reasonable action in only kicking, without an object that can be kicked. That's why I'd put a sensor (switch) near the feet of the infant, that will signal a kick.
