I have a question i read several topics but i dont understun why we need limit the input current at 250 mA. Becasue the datasheet of the voltage regulator (AMS1117) give : Current Limit out = 1.1 A therefore Poutmax=1.1A*5V=5.5W and after measure i have : Iin = 0.3A for an input voltage of 9V therefore Pin=2.5w.
Please can you explain me why it a problem ?
Other solution i think design one supply board and powered the arduino mega by the USB Port.
crevette24:
Seems you calculate power in the LOAD, not in the regulator.
For 9volt in and 5volt out, at 300mA, the regulator dissipates (9-5) * 0.3 = 1.2watt.
That is already a lot for the small heatsink area of an Arduino.
Look at the thermal table on page5 of the AMS1117 datasheet.
Say the heatsink area is 225 square mm.
The chip (inside) will rise 65degrees above ambient for every watt.
1.2watt from above will be (1.2 * 65) + ~25 (ambient) = 103 degrees C.
The chip will shut down at 165C.
What is your exact problem.
Maybe there is another way to solve it
Leo..
Thank for your answer,
For the moment i dont have a problem but i am worried for the future. In fact i have a touch screen + shield + display + 3*optocoupler.
i think use an external voltage regulator and use a USB port to powered the arduino.
Ok, but what I mean is that powering via USB connector doesn't allow more current. In fact, it is the opposite.
And if you want to power via USB connector, you need a regulated 5V supply - If it works now with the USB connected to a PC, than it will work if you power it via the power jack (7V - 12V ) or the Vin pin (7V-12V too) without any modification of your shield.
Both will work..... use the way you like, the simpler the better
