All right, but it's huge!
/* Added curentWaypoint for function with GPS waypoints
* Added if ((gps.location.isValid()) && (currentWaypoint == '0'))
* Added "HOME". Added code to change Name of GPS Waypoint. WAYPOINT & HOME
* MEGA must be connected or you will get "Serial1 was not declared in this scope" error
* MEGA ***This is the one for Capitol Airport ***
* Removed Date and Time
* RED TFT (ILI9341)
* Pin19 to 4th pin on sensor
* GPS Sensor GT-U7
* Displays Compass and GPS headers, SEEMS TO WORK!
* Changed KPH to MPH
* Changed Altitude Meters to Feet
* Added GPS Valid Gren/Red box ***ONLY valid if
* GPS SAT signal is lost, not if wire #19 is
* pulled out and Arduino is not receiving signals.***
* Added Dist and Heading to Capitol Airport Waukesha WI (can be changed)
* NEED TO FIX GPS TIME ******************************************************
#include <TinyGPSPlus.h>
#include <SoftwareSerial.h>
static const int RXPin = 18, TXPin = 19;
static const uint32_t GPSBaud = 9600;
#include <Arduino.h>
#define USE_ADAFRUIT_SHIELD_PINOUT 1
#include <Adafruit_GFX.h>
#include <Adafruit_Sensor.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
TinyGPSPlus gps; // May have GPS TIME calculations
#include <SPI.h>
#include "Adafruit_GFX.h"
#include "Adafruit_ILI9341.h"
// Assign names to common 16-bit color values:
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define YELLOW 0xFFE0
#define ORANGE 0xFD20
#define WHITE 0xFFFF
String Time, Date;
float NumberSats, Latitude, Longitude, Bearing;
float AltitudeMETRES, AltitudeMILES, AltitudeKM, AltitudeFEET;
float SpeedKPH, SpeedMPH, SpeedKNOTS, SpeedMPS;
//float distanceToWAYPOINT; /////////////////////////
const int centreX = 230; // Location of the compass display on screen
const int centreY = 120;
const int diameter = 70; // Size of the compass
int dx = centreX, dy = centreY;
int last_dx = centreX, last_dy = centreY - diameter * 0.85;
int currentWaypoint = 0;
// For stats that happen every 5 seconds
unsigned long last = 0UL;
Serial1.begin(9600); // connect gps sensor
//ss.begin(GPSBaud);
//Serial.print("What the HECK!");
tft.begin(); // Start the TFT display
tft.setRotation(5); // Rotate screen by 90°
tft.setTextSize(2); // Set medium text size
tft.setTextColor(YELLOW);
tft.fillScreen(BLACK);
currentWaypoint = '0'; // 0=CAPITOL, 1=HOME, 2=HOLY HILL, 3=CARL, 4=???
Latitude = gps.location.lat();
Longitude = gps.location.lng();
Bearing = gps.course.deg();
SpeedMPH = gps.speed.mph();
NumberSats = gps.satellites.value();
AltitudeMETRES = gps.altitude.meters(); // KEEP THIS!
AltitudeFEET = gps.altitude.feet();
// ********* GPS GOOD? This works ONLY if SAT signal is lost NOT if Pin19 is pulled out *******
if (gps.satellites.value ()> 3 )
tft.fillRect(0, 0, 30, 8 * 4, GREEN);
tft.fillRect(0, 0, 30, 8 * 4, RED); //left,top,right,down * 4?, Green
// *** Adding Dist & Course to WAYPOINT *******************************************
PrintText(20, 0, " CAPITOL", CYAN, 2);
//PrintText(40, 0, "distanceToWAYPOINT:" + String(),2, 2); //////////////
tft.fillRect(45, 40, 90, 19 * 4, BLACK); //LAT, LONG, ALT, SAT area
static const double WAYPOINT_LAT = 43.089619, WAYPOINT_LON = -88.179440;
double distanceToWAYPOINT =
TinyGPSPlus::distanceBetween(gps.location.lat(), gps.location.lng(), WAYPOINT_LAT, WAYPOINT_LON);
double courseToWAYPOINT = TinyGPSPlus::courseTo(gps.location.lat(), gps.location.lng(), WAYPOINT_LAT, WAYPOINT_LON);
tft.setTextColor(CYAN);
tft.setCursor(150, 0); // Sets it back to not print over "WAYPOINT"
tft.println(TinyGPSPlus::cardinal(courseToWAYPOINT)); // Prints "cardinal heading (SE) to gps location" on TFT
tft.setCursor(190, 0);
tft.println(distanceToWAYPOINT/1000*.6213712, 1); // Prints Distance to WAYPOINT calculated for miles
tft.setCursor(250, 0);
tft.print("Miles");
// end Addding Distance & Heading to WAYPOINT
// *** Adding Dist & Course to Home *******************************************
if ((gps.location.isValid()) && (currentWaypoint == '1'))
PrintText(20, 0, " HOME", CYAN, 2);
static const double WAYPOINT_LAT = 43.200000, WAYPOINT_LON = -88.300000;
TinyGPSPlus::courseTo( gps.location.lat(), gps.location.lng(), WAYPOINT_LAT, WAYPOINT_LON);
tft.print("Miles");
// end Addding Distance & Heading to HOME
if ((gps.location.isValid()) && (currentWaypoint == '3'))
PrintText(20, 0, " CARL", CYAN, 2);
static const double WAYPOINT_LAT = 43.369462, WAYPOINT_LON = -88.592716;
tft.print("Miles");
// end Addding Distance & Heading to CARL
if ((gps.location.isValid()) && (currentWaypoint == '2'))
PrintText(20, 0, " HOLY HILL", CYAN, 2);
static const double WAYPOINT_LAT = 43.140000, WAYPOINT_LON = -88.190000;
tft.setCursor(235, 0);
tft.print("Miles");
// end Addding Distance & Heading to HOLY HILL
while (Serial1.available() > 0)
gps.encode(Serial1.read());
if (gps.location.isUpdated())
Serial.print(F("LOCATION Fix Age="));
//Serial.print("***************");
Serial.print(gps.location.isUpdated());
//Serial.print(gps.location.age());
//Serial.print(F("ms Raw Lat="));
//Serial.print(gps.location.rawLat().negative ? "-" : "+");
//Serial.print(gps.location.rawLat().deg);
//Serial.print("[+");
//Serial.print(gps.location.rawLat().billionths);
//Serial.print(F(" billionths], Raw Long="));
//Serial.print(gps.location.rawLng().negative ? "-" : "+");
//Serial.print(gps.location.rawLng().deg);
//Serial.print(gps.location.rawLng().billionths);
//Serial.print(F(" billionths], Lat="));
//Serial.print(gps.location.lat(), 6);
//Serial.print(F(" Long="));
//Serial.println(gps.location.lng(), 6);
//Serial.println("Time\t\tDate\t\tLAT\tLON\tSATS\tAlt\tBearing\tSpeed(KPH)");
//Serial.println("----------------------------------------------------------------------------------");
//Serial.print(Time + "\t");
//Serial.print(Date + "\t");
//Serial.print(String(Latitude, 3) + "\t");
//Serial.print(String(Longitude, 3) + "\t");
//Serial.print(String(NumberSats) + "\t");
//Serial.print(String(AltitudeMETRES) + "\t"); // Select as required
//Serial.print(String(Bearing) + "\t");
//Serial.print(String(SpeedKPH) + "\t"); // Select as required
//Serial.print(String(SpeedMPH) + "\t"); // Select as required
//Serial.print(String(distanceToWAYPOINT) + "\t"); ///////////////////////////////
//Serial.println("\n");
DisplayGPSdata(NumberSats, Latitude, Longitude, AltitudeMETRES, SpeedKPH, Bearing); // Select units as required
smartDelay(1000);
if (millis() > 5000 && gps.charsProcessed() < 10) Serial.println(F("No GPS data received: check wiring"));
void DisplayGPSdata(float dNumberSats, float dLatitude, float dLongitude, float dAltitude, float dSpeed, float dBearing) {
// PrintText(20, 0, " WAYPOINT", CYAN, 2);
// //PrintText(40, 0, "distanceToWAYPOINT:" + String(),2, 2); //////////////
// tft.fillRect(45, 40, 90, 19 * 4, BLACK);
PrintText(0, 45, "LAT:" + String(dLatitude), YELLOW, 2);
PrintText(0, 63, "LON:" + String(dLongitude), YELLOW, 2);
PrintText(0, 81, "ALT:" + String(dAltitude * 3.28084, 1) + " FT", WHITE, 2);
PrintText(0, 99, "SAT:" + String(dNumberSats, 0), YELLOW, 2);
tft.fillRect(100, 220, 120, 22, BLACK); // Left side to side, up and down, Right amount long, down for an amount, color (Blacks out old speed)
PrintText(10, 220, "SPEED " + String(dSpeed / 1.609) + " Mph", RED, 3); //
// tft.fillRect(220, 218, 120, 18, BLACK); // This was on far right of screen for ???
tft.setCursor(200, 220);
Display_Compass(dBearing);
void Display_Compass(float dBearing) {
int dxo, dyo, dxi, dyi;
tft.setCursor(0, 0);
tft.drawCircle(centreX, centreY, diameter, WHITE); // Draw compass circle
for (float i = 0; i < 360; i = i + 22.5) {
dxo = diameter * cos((i - 90) * 3.14 / 180);
dyo = diameter * sin((i - 90) * 3.14 / 180);
dxi = dxo * 0.9;
dyi = dyo * 0.9;
tft.drawLine(dxo + centreX, dyo + centreY, dxi + centreX, dyi + centreY, WHITE);
PrintText((centreX - 5), (centreY - diameter - 18), "N", GREEN, 2);
PrintText((centreX - 5), (centreY + diameter + 5) , "S", GREEN, 2);
PrintText((centreX + diameter + 5), (centreY - 5), "E", GREEN, 2);
PrintText((centreX - diameter - 15), (centreY - 5), "W", GREEN, 2);
dx = (0.85 * diameter * cos((dBearing - 90) * 3.14 / 180)) + centreX; // calculate X position ( Change dBearing to bearing? to get to WAYPOINT Airport?)
dy = (0.85 * diameter * sin((dBearing - 90) * 3.14 / 180)) + centreY; // calculate Y position
draw_arrow(last_dx, last_dy, centreX, centreY, 5, 5, BLACK); // Erase last arrow
draw_arrow(dx, dy, centreX, centreY, 5, 5, YELLOW); // Draw arrow in new position
last_dx = dx;
last_dy = dy;
void draw_arrow(int x2, int y2, int x1, int y1, int alength, int awidth, int colour) {
float distance;
int dx, dy, x2o, y2o, x3, y3, x4, y4, k;
distance = sqrt(pow((x1 - x2), 2) + pow((y1 - y2), 2));
dx = x2 + (x1 - x2) * alength / distance;
dy = y2 + (y1 - y2) * alength / distance;
k = awidth / alength;
x2o = x2 - dx;
y2o = dy - y2;
x3 = y2o * k + dx;
y3 = x2o * k + dy;
x4 = dx - y2o * k;
y4 = dy - x2o * k;
tft.drawLine(x1, y1, x2, y2, colour);
tft.drawLine(x1, y1, dx, dy, colour);
tft.drawLine(x3, y3, x4, y4, colour);
tft.drawLine(x3, y3, x2, y2, colour);
tft.drawLine(x2, y2, x4, y4, colour);
//###########BEARING TO GPS WAYPOINT ############### bearing is from "Bearing = gps.course.deg();"
String Bearing_to_Ordinal(float bearing) {
if (bearing >= 348.75 || bearing < 11.25) return "N";
if (bearing >= 11.25 && bearing < 33.75) return "NNE";
if (bearing >= 33.75 && bearing < 56.25) return "NE";
if (bearing >= 56.25 && bearing < 78.75) return "ENE";
if (bearing >= 78.75 && bearing < 101.25) return "E";
if (bearing >= 101.25 && bearing < 123.75) return "ESE";
if (bearing >= 123.75 && bearing < 146.25) return "SE";
if (bearing >= 146.25 && bearing < 168.75) return "SSE";
if (bearing >= 168.75 && bearing < 191.25) return "S";
if (bearing >= 191.25 && bearing < 213.75) return "SSW";
if (bearing >= 213.75 && bearing < 236.25) return "SW";
if (bearing >= 236.25 && bearing < 258.75) return "WSW";
if (bearing >= 258.75 && bearing < 281.25) return "W";
if (bearing >= 281.25 && bearing < 303.75) return "WNW";
if (bearing >= 303.75 && bearing < 326.25) return "NW";
if (bearing >= 326.25 && bearing < 348.75) return "NNW";
return "?";
void PrintText(int x, int y, String text, int colour, byte text_size) {
tft.setCursor(x, y);
tft.setTextColor(colour);
tft.setTextSize(text_size);
tft.print(text);
tft.setTextColor(YELLOW); // Default colour
tft.setTextSize(2); // Default Text Size
static void smartDelay(unsigned long ms) {
unsigned long start = millis();
do {
while (Serial1.available()) gps.encode(Serial1.read());
} while (millis() - start < ms);
