Hello everyone. I am new to forum and arduino programmiring.
Right now I am working on my biggest project so far and I need help. I am using arduino UNO, Arduino CNC sheield V3 limit switch named tiaihua and stepper motor Nema 17 bipolar. All I want is for the motor to spin until it reaches the limit switch. When the limit switch is activated, the motor would simply change direction and rotate again all the way to the second limit switch where it would do the same. I don't know where I have mistake, please help.
#define EN 8
#define X_DIR 5
#define X_STP 2
int delayTime=1500; //Delay between each pause (uS)
long int stps=4000;// microsteps per revolution with 1/32 microstepping
const int limitPin = 9; //enable limitPin
void step(boolean dir, byte dirPin, byte stepperPin, long int steps)
digitalWrite(dirPin, dir);
for (long int i = 0; i < steps; i++) {
digitalWrite(stepperPin, HIGH);
delayMicroseconds(delayTime);
digitalWrite(stepperPin, LOW);
pinMode(X_DIR, OUTPUT);
pinMode(X_STP, OUTPUT);
pinMode(EN, OUTPUT);
pinMode(limitPin, INPUT_PULLUP);
digitalWrite(EN, LOW);
if( digitalRead(limitPin) == HIGH){
step(false, X_DIR, X_STP, stps);
if( digitalRead(limitPin) == LOW)
step(true, X_DIR, X_STP, stps);
limit switch is wired to end stops pin X+ (red and blach-C and ND)
