Hello!
I'm trying to use a limit switch to stop a stepper motor and enable an other one. I first tryed the 'while' function but I had the error ; could not convert from 'void' to 'bool'.
Here is a little exemple of my try :
while (myMotor1->step(1640, BACKWARD, DOUBLE));
val = digitalRead(inPin);
if (val == HIGH) {
myMotor2->step(1640, BACKWARD, DOUBLE);
#SORRYIMATOTALBEGINNER
Thank you for your help!
Please read the "how to use the forum " stickies. Read #7 and #11 carefully.
system
May 10, 2017, 12:04pm
3
This is wrong. The step() method does not return a value.
You are going about this wrong.
What you want to do is something like this:
one: check if at limit.
if not at limit
step ONCE
go to one:
Of course, we'll slap you silly if you actually use goto. The idea is to move one step at a time, toward the switch, while the switch is not pressed.
benjoulx:
How come this is almost identical to this other Thread to which I have already replied - and apparently been ignored?
If the other Thread is yours under a different name please click "Report to Moderator" and ask to have it merged with this Thread.
...R
Hello Robin2. I just reported it to the moderator.
Come on, stay calm.
benjoulx:
Come on, stay calm.
I would be more calmed if I thought you had taken any notice of the Reply I gave in the other Thread.
...R
Actually I did. I just did not have time to reply yet.
Hi PaulS,
So what is the solution for not using 'goto' ?
Thank you for taking the time to answer!
Use [functions](http://So what is the solution for not using 'goto' ?)
