LIN master program
I'm going to use LIN(Local Interconnect Network) master with UNO-R4-minima.
Do anyone use LIN master with UNO-R4-minima?
Or knows how to use LIN master with UNO-R4-minima?
Not knowing what you want to communicate with the best suggestion I can make is: Introduction to the LIN Bus Protocol - NI
Thank you replay!!
I want to send LIN message to a device from UNO R4 minima, not use "CANoe" or "micropecker".
AND Then after the device receives the LIN message it works and outputs some signals to the UNO R4.
My purpose is to switch the behavior of the UNO R4 based on that output.
I looked for some library on this forum, but I can't this.
(for example, not supported UNO R4)
