According to the input given via keypad sometimes the robot must take a left and at times take a right at a tee junction. But the robot always takes only a right or only a left at the tee junction. What must I do?
I have attached my code. I have used an RFID reader and tag to stop.
Ok. Even if you just ignore the code, my only doubt is how do I make the robot take a right turn at a T junction. At times it takes a left and at times a right.
There's no chance of my forgetting that code because it is completely mine and I work with it for about four hours a day. Those are just sensor positions. But I apologise for not adding comments. I agree it looks a mess for an outsider.
@sulivuli, In addition to what has already been said it seems to me unreasonable to expect someone to "debug" 17.4k of code without a single indication of where the problem may lie and no indication of the steps you have taken to find the problem yourself.
Debugging requires a a lot of patience and attention to detail and the starting point is to display the progress of the code and the values of key variables with Serial.print() statements. Checking the values of variables immediately before they are used in IF statements can be instructive.
Have a look at how the code is organized in Planning and Implementing a Program. Small single purpose functions can be tested in isolation from the rest of the code. Meaningful function and variable names (including pin references) are essential.
That should be a single function, called 78 times (and even that could be factored-down, I suspect)
You have 64 occurrences of (digitalRead(2)==HIGH && digitalRead(3)==HIGH && digitalRead(7)==HIGH && digitalRead(4)==HIGH)
That should also be a single function.
Use sensible names for pins, not just numbers.
And auto-format your code - it's virtually illegible.
And comments.
You must comment, and not the sort of comment that repeats verbatim what the code has already told us.
sulivuli:
This statement is only true now. Tell me you can say the same thing is 30 years after you have written millions of lines of code!
I have had to revise code that I wrote 30 years ago. Without descriptive comments, meaningful variable/function names it is easier to start from scratch.
Have you ever heard of 'DOS' COM files or Overlay's? how about Segments? Interrupt 21? Let alone what the parameters are for:
lds dx,Buf1
mov [dx], 7
mov ah, 10
int 21h
Any Idea what this code does? It reads upto 7 characters from the keyboard, Storing them in the memory point to by DS:DX
