Am in process of building a line follower bot using ArduinoBoardDuemilanove and Line sensor array purchased from roboworld
The Sensor array requires 300mA however Arduino provided 30mA at 5v.So am using exteranal supply.Am confused regarding the connection between Arduino and sensor array.
In the manual it was written to short gnd of sensor with microconroller gnd
so is this connection correct??
Sensor array gives TTL output so should i connect them to digital pins or analog pins of arduino.And how to caliberate the sensor array.
First, you should post links to the devices you are asking about.
Second, there is a difference between connecting ground of the sensor to ground of the Arduino and shorting something out. Connecting the grounds together is required. Shorting something is NOT.
This is an easy-to-use module with 7 reflective sensors. It can be easily used with a microcontroller as it gives TTL compatible outputs. The output pins can be directly connected to microcontroller pins which give active low output when white line is detected.
