Line follower bot with IR sensor array
Hello everyone. This is my first time working with an arduino. I'am building a line follower bot using an IR array which has 8 IR sensors. I'am using a L293D motor shield with 2 motors connected to input 1 and 4 of the shield.
I imported the adafruit motor shield library and ran its motor test example and it worked fine.
Here's the example code:
#include <AFMotor.h>
AF_DCMotor motor(4);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Motor test!");
  // turn on motor
  motor.setSpeed(200);
  motor.run(RELEASE);
  uint8_t i;
  Serial.print("tick");
  motor.run(FORWARD);
  for (i=0; i<255; i++) {
    motor.setSpeed(i);
    delay(10);
  for (i=255; i!=0; i--) {
    motor.setSpeed(i);
    delay(10);
  Serial.print("tock");
  motor.run(BACKWARD);
    motor.setSpeed(i);
    delay(10);
    motor.setSpeed(i);
    delay(10);
  Serial.print("tech");
  motor.run(RELEASE);
But for some reason the code I wrote for my bot isn't working...
Here's the code:
#include<AFMotor.h>
AF_DCMotor motor1(1);
AF_DCMotor motor2(4);
int DS1 = 2;
int DS2 = 3;
int DS3 = 4;
int DS4 = 5;
int DS5 = 6;
int DS6 = 7;
int DS7 = 8;
int DS8 = 9;
 motor1.setSpeed(200);
 motor2.setSpeed(200);
 pinMode(DS1,INPUT);
 pinMode(DS2,INPUT);
 pinMode(DS3,INPUT);
 pinMode(DS4,INPUT);
 pinMode(DS5,INPUT);
 pinMode(DS6,INPUT);
 pinMode(DS7,INPUT);
 pinMode(DS8,INPUT);
 motor1.run(RELEASE);
 motor2.run(RELEASE);
 uint8_t mx = 255;
 uint8_t tmax = 191;
 uint8_t hmax = 127;
 uint8_t omax = 64;
 uint8_t lw = 0;
 int S1 = digitalRead(DS1);
 int S2 = digitalRead(DS2);
 int S3 = digitalRead(DS3);
 int S4 = digitalRead(DS4);
 int S5 = digitalRead(DS5);
 int S6 = digitalRead(DS6);
 int S7 = digitalRead(DS7);
 int S8 = digitalRead(DS8);
 Serial.print(S1);
 Serial.print(S2);
 Serial.print(S3);
 Serial.print(S4);
 Serial.print(S5);
 Serial.print(S6);
 Serial.print(S7);
 Serial.print(S8);
 Serial.print("\n");
 if( S1 == 1 && S2 == 1 && S3 == 1 && S4 == 0 && S5 == 0 && S6 == 1 && S7 == 1 && S8 == 1 ) //Centre
     motor1.run(FORWARD);
     motor1.setSpeed(mx);
     motor2.run(FORWARD);
     motor2.setSpeed(mx);
 else if( S1 == 1 && S2 == 1 && S3 == 0 && S4 == 0 && S5 == 1 && S6 == 1 && S7 == 1 && S8 == 1 ) //75 Left
     motor1.setSpeed(tmax);
 else if( S1 == 1 && S2 == 0 && S3 == 0 && S4 == 1 && S5 == 1 && S6 == 1 && S7 == 1 && S8 == 1 ) //50 Left
     motor1.setSpeed(hmax);
 else if( S1 == 0 && S2 == 0 && S3 == 1 && S4 == 1 && S5 == 1 && S6 == 1 && S7 == 1 && S8 == 1 ) //25 Left
     motor1.setSpeed(omax);
 else if( S1 == 0 && S2 == 1 && S3 == 1 && S4 == 1 && S5 == 1 && S6 == 1 && S7 == 1 && S8 == 1 ) //0 Left
     motor1.setSpeed(lw);
 else if( S1 == 0 && S2 == 0 && S3 == 0 && S4 == 0 && S5 == 0 && S6 == 1 && S7 == 1 && S8 == 1) //Left L
 else if( S1 == 1 && S2 == 1 && S3 == 1 && S4 == 1 && S5 == 0 && S6 == 0 && S7 == 1 && S8 == 1 ) //75 Right
     motor2.setSpeed(tmax);
 else if( S1 == 1 && S2 == 1 && S3 == 1 && S4 == 1 && S5 == 1 && S6 == 0 && S7 == 0 && S8 == 1 ) //50 Right
     motor2.setSpeed(hmax);
 else if( S1 == 1 && S2 == 1 && S3 == 1 && S4 == 1 && S5 == 1 && S6 == 1 && S7 == 0 && S8 == 0 ) //25 Right
     motor2.setSpeed(omax);
 else if( S1 == 1 && S2 == 1 && S3 == 1 && S4 == 1 && S5 == 1 && S6 == 1 && S7 == 1 && S8 == 0 ) //0 Right
     motor2.setSpeed(lw);
 else if( S1 == 0 && S2 == 0 && S3 == 0 && S4 == 0 && S5 == 0 && S6 == 1 && S7 == 1 && S8 == 1) //Right L
 else if( S1 == 1 && S2 == 1 && S3 == 1 && S4 == 1 && S5 == 1 && S6 == 1 && S7 == 1 && S8 == 1 ) //All White
 else if( S1 == 0 && S2 == 0 && S3 == 0 && S4 == 0 && S5 == 0 && S6 == 0 && S7 == 0 && S8 == 0 ) //All Black
The IR sensor is receiving input and is being stored in the variables as intended. But the motors didn't run no matter what I did. Am I doing something wrong?
As long as the motors only run forward, you can omit the motor.run(FORWARD); calls.
I'd simply sum up the left and the right hand sensor values, and with their difference determine the speed of the motors.
