Line follower - Only 2 cases
Hello! I am participating in an robotics contest with a line follower. The robot is programed a bit different since the driver is programed with serial. They provided a basic code for the robot but it only has 2 cases. In all other sites that show how to program an line follower robot they have 4 cases. Because of the 2 cases even when both sensors are on white he keeps turning left and right. I would really apriciate it if someone could add a 3rd case to my code for when both sensors are on white. Thanks!
volatile byte beggining;
volatile byte forward;
volatile byte backwards;
volatile int stare;
volatile int sensorLeft;
volatile int sensorRight;
void setup(){
  beggining = 254;
  forward = 240;
  backwards = 186;
  stare = 0;
  sensorLeft = 0;
  sensorRight = 0;
  pinMode(3, INPUT);
  pinMode(9, INPUT);
void loop(){
  sensorLeft = digitalRead(3);
  sensorRight = digitalRead(9);
  if (sensorLeft == 1) {
    if (sensorRight == 1) {
      state = 0;
      state = 1;
  } else if (sensorRight == 1) {
    state = -1;
  switch (state) {
   case -1:
    Serial.write(beggining);
    Serial.write(1);
    Serial.write(forward);
    Serial.write(50);
    Serial.write(2);
    Serial.write(0);
   case 1:
    Serial.write(1);
    Serial.write(0);
    Serial.write(2);
    Serial.write(50);
   default:
    Serial.write(1);
    Serial.write(50);
    Serial.write(2);
    Serial.write(50);
Thanks again!
You have far too much white space in your program - it makes it very hard to read.
The following is how I would do it. I convert the left and right sensor values into a single number which might be 10, 11 or 1 depending on which sensors are detected.
I have also made the states characters to make the code clearer - no need to remember what 1 or -1 means.
void loop(){
  sensorsCombined = sensorLeft * 10 + sensorRight;
  if (sensorsCombined == 11) {
    state == 'S'; // S for straight, L for left, R for Right
  else if (sensorsCombined == 10) {
    state = 'L';
  else if (sensorsCombined == 1) {
    state = 'R'
  switch (state) {
   case 'S':
    Serial.write(1);
    Serial.write(50);
    Serial.write(2);
    Serial.write(0);
   case 'L':
    Serial.write(1);
    Serial.write(0);
    Serial.write(2);
    Serial.write(50);
   case 'R':
     // need to put appropriate code here
   default:
    Serial.write(1);
    Serial.write(50);
    Serial.write(2);
    Serial.write(50);
...R
Thanks
