Line follower - please help
I was programming my robot to follow a black line. here is the code
int irPin1 = 1 ; // sensor 1
int irPin2 = 2 ;  // sensor 2
boolean State1 ;  //  LOW = BLACK, HIGH = WHITE
boolean State2 ;
int ic2 = 3 ;   //pin 2 of l293d
int ic7 = 5 ;   // pin 7
int ic10 = 6 ; // pin10
int ic15 = 9 ; // pin 15
void setup(){
  pinMode(irPin1, INPUT);
  pinMode(irPin2, INPUT);
  pinMode(ic2, OUTPUT) ;
  pinMode(ic7, OUTPUT) ;
  pinMode(1c10, OUTPUT);
  pinMode(ic15, OUTPUT) ;
    digitalWrite(13, HIGH) ;
  delay(500) ;
 digitalWrite(13, LOW) ;
void loop(){
   State1 = digitalRead(irPin1);   // read the reference state
   State2 = digitalRead(irPin2);
    while(State1 == HIGH && State2 == HIGH)
     digitalWrite(ic2, HIGH) ;
     digitalWrite(ic7, LOW) ;
     digitalWrite(ic10, LOW) ;
     digitalWrite(ic15, HIGH) ;
   while(State1 == HIGH && State2 == LOW)
     digitalWrite(ic15, LOW) ;
   while(State1 == LOW && State2 == HIGH)
     digitalWrite(ic2, LOW) ;
     digitalWrite(ic10, HIGH) ;
here is the error
sketch_aug08a.cpp:19:11: error: invalid suffix "c10" on integer constant
googled it, but got no useful result.
P.S. it's just a basic code.
IR sensors are used .
Looks like the compiler nailed that one.
(PS, we don't care what the sensors are, neither does the compiler)
Thx a ton...AWOL :D..:D.
and will this coding work..? sensor give 2.5V when HIGH and 0v when LOW
What does the datasheet say?
From “28.2 DC Characteristics”:
VIH for VCC = 2.4V - 5.5V Min. 0.6VCC
So, no, probably not.
I didn't got you and sorry no data sheet
I didn't got you
I don't understand what you're saying.
sorry no data sheet
You should get one - just go to the Atmel site and download it.
