Line Follower Robot not moving forward
Hello guys. I am new to arduino. I made line follower robot that should be following the black line. I wrote some code, but my robot does not move forward. I wonder if I messed up somewhere in the code I would be very thankful for some tips and answers. Cheers. Here is my code:
#define LS 2 // left sensor
#define RS 3 // right sensor
#define LM1 5 // left motor M1a
#define LM2 4 // left motor M2a
#define RM1 7 // right motor M2a
#define RM2 6 // right motor M2b
pinMode(LS, INPUT);
pinMode(RS, INPUT);
pinMode(LM1, OUTPUT);
pinMode(LM2, OUTPUT);
pinMode(RM1, OUTPUT);
pinMode(RM2, OUTPUT);
if(digitalRead(LS) && digitalRead(RS)) // Move Forward on line
digitalWrite(LM1, HIGH);
digitalWrite(LM2, LOW);
digitalWrite(RM1, HIGH);
digitalWrite(RM2, LOW);
if(digitalRead(LS) && !(digitalRead(RS))) // turn left by rotationg left motors in forward and right ones in backward direction
digitalWrite(LM1, LOW);
digitalWrite(LM2, HIGH);
if(!(digitalRead(LS)) && digitalRead(RS)) // Turn right by rotating right motors in forward and left ones in backward direction
digitalWrite(RM1, LOW);
digitalWrite(RM2, HIGH);
if(!(digitalRead(LS)) && !(digitalRead(RS))) // Finish line, stop both the motors
It may be a wiring problem: have you tested your motors before coding the sensors? Try a simple code as:
and see if you wheels work as expected.
You should store the sensors readings in variables to do the if tests, such as:
bool leftSensor = digitalRead(LS);
bool rightSensor = digitalRead(RS);
if(leftSensor  && rightSensor) // Move Forward on line
But you haven't told us about your sensors and Arduino board: any references? Are you sure these sensors provide digital information?
Yes I did test the motors and the wheels work like they should.
So maybe the problem is I didn't store the sensors readings into the variables? Should definitely try that.
Oh sorry I'm new to the forum so yeah...
I use arduino uno board and I use 2 IR Infrared Obstacle Avoidance Sensors I bought off ebay.
Thank you for your answer!
And have you checked you sensors alone?
Use a simple sketch
void loop() { Serial.println(digitalRead(LS)); }
and move your sensor on and off the line you want to follow to see what the sensor tells you.
Yes the sensors work like they should.
I changed the code and this is how it looks now.. but now the robot is just driving and not stopping when it doesn't get any light..
pinMode(LS, INPUT);
pinMode(RS, INPUT);
if(leftSensor && !(rightSensor)) // turn left by rotationg left motors in forward and right ones in backward direction
if(!(leftSensor) && rightSensor) // Turn right by rotating right motors in forward and left ones in backward direction
if(!(leftSensor) && !(rightSensor)) // Finish line, stop both the motors
Needs to be in loop ().
Please remember to use code tags when posting code.
I did put them in the loop but I get this error: expected initializer before 'bool'
And sorry about the tags!
Have we seen the code that gives you that error?
Here si the code
pinMode(LS, INPUT);
pinMode(RS, INPUT);
Something missing here
Something like this?
Instead of
Do this
void loop() { // <-- here !
Thank you guys for answers this is the code now
void setup(){
  pinMode(LS, INPUT);
  pinMode(RS, INPUT);
void loop(){
  if(leftSensor && rightSensor){
    // Move forward
  if(leftSensor && !(rightSensor)){
    // turn left by rotating left motor forward and right motor backwards
  if(!(leftSensor) && rightSensor){
    // turn right by rotating right motor forward and left motor backwards
  if(!(leftSensor) && !(rightSensor)){
    // stop both motors
And the problem is still there the robot does not move forward on the line… when i lift it in the air the wheels start spinning… as soon as I put it down on the line it does not move forward
