Hey Arduino Forum.
I am trying to make my line follower better, and wanted to change my IF statements to only run the code if the sensors see HIGH or LOW in an amount of time.
How would i do this?
This is my code so far: (running with 3 sensors, and this code works, just wanna improve it)
//libraries
#include <TimerOne.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
//Ports assigned
int IR_left = 2; //IR sensor on port D2
int IR_right = 4; //IR sensor on port D4
int IR_mid = 3; //IR sensor on port D3
int normal = 100; // default Speed of motors (0-255)
int maxspeed = 255; //max speed of motors (0-255)
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_DCMotor *motor_right = AFMS.getMotor(1); //motor 1 on port M1
Adafruit_DCMotor *motor_left = AFMS.getMotor(2); //motor 2 on port M2
void setup(){
AFMS.begin();
motor_left->setSpeed(normal);
motor_right->setSpeed(normal);
pinMode(IR_left, INPUT);
pinMode(IR_right, INPUT);
pinMode(IR_mid, INPUT);
void loop(){
if ((LOW == digitalRead(IR_left)) && (LOW == digitalRead(IR_right)) && (HIGH == digitalRead(IR_mid))){
motor_left->run(FORWARD);
motor_right->run(FORWARD);
else {
if(HIGH == digitalRead(IR_mid)){
if(HIGH == digitalRead(IR_left)){
motor_left->setSpeed(maxspeed);
else{
motor_right->setSpeed(maxspeed);
else{
motor_left->run(BACKWARD);
motor_right->run(BACKWARD);
