I am trying to make a line follower robot and this is the code I have been using
#include <Arduino.h>
#include <Wire.h>
#include <VL53L0X.h>
#include <TimerOne.h>
#include <QTRSensors.h>
#define NUM_MOTORS 2
#define SensorCount 5
#define WHEEL_RADIUS 0.035
#define DT 0.040
#define WHEEL_DIST 0.125
#define NUM_SAMPLES 4
QTRSensors qtr;
volatile uint16_t position;
uint16_t sensorValues[SensorCount];
//PID CONTROL
float Kp = 2.2; //2.2
float Ki = 0;
float Kd = 4; //4
volatile int P;
volatile int I;
volatile int D;
volatile int motorspeed;
volatile int lastError;
volatile int error;
int maxspeeda = 750;
int maxspeedb = 750;
int basespeeda = 400;
int basespeedb = 400;
const int encoder0A_pin = 2; // Motor1 encoder A input
const int encoder0B_pin = 3; // Motor1 encoder B input
const int encoder1A_pin = 4; // Motor2 encoder A input
const int encoder1B_pin = 5; // Motor2 encoder B input
const int M1_dir_pin = 8; // Motor1 Dir output
const int M2_dir_pin = 11; // Motor2 Dir output
const int M1_PWM_pin = 9; // Motor1 PWM output
const int M2_PWM_pin = 10; // Motor2 PWM output
volatile int M_PWM_value[NUM_MOTORS];
uint8_t LED_state;
static void set_M1_PWM(volatile int new_PWM)
if (new_PWM >= 0) {
M_PWM_value[0] = new_PWM;
digitalWrite(M1_dir_pin, false);
}else if (new_PWM < 0){
M_PWM_value[0] = -new_PWM;
digitalWrite(M1_dir_pin, true);
Timer1.setPwmDuty(TIMER1_A_PIN, M_PWM_value[0]);
static void set_M2_PWM(volatile int new_PWM)
if (new_PWM >= 0) {
M_PWM_value[1] = new_PWM;
digitalWrite(M2_dir_pin, false);
M_PWM_value[1] = -new_PWM;
digitalWrite(M2_dir_pin, true);
Timer1.setPwmDuty(TIMER1_B_PIN, M_PWM_value[1]);
void calibration() {
digitalWrite(LED_BUILTIN, HIGH);
for (uint16_t i = 0; i < 400; i++)
qtr.calibrate();
digitalWrite(LED_BUILTIN, LOW);
void PID_control() {
error = 2000 - position;
P = error;
I += error;
D = error - lastError;
lastError = error;
motorspeed = P*Kp + D*Kd + I*Ki;
if (motorspeed > 200 || motorspeed < -200){
I -= error;
M_PWM_value[0] = basespeeda - motorspeed;
M_PWM_value[1] = basespeedb + motorspeed;
if (M_PWM_value[0] > maxspeeda) {
M_PWM_value[0] = maxspeeda;
}else if (-M_PWM_value[0] > maxspeeda){
M_PWM_value[0] = -maxspeeda;
if (M_PWM_value[1] > maxspeedb) {
M_PWM_value[1] = maxspeedb;
}else if (-M_PWM_value[1] > maxspeedb){
M_PWM_value[1] = -maxspeedb;
typedef enum {
cm_pwm,
cm_pid
} control_mode_t;
typedef struct {
//float v1e, v2e;
float ve, we;
float ds, dtheta;
float rel_s, rel_theta;
float x, y, theta;
uint8_t state, new_state, prev_state;
uint32_t tis, tes;
float dt;
float v, w;
float v_req, w_req;
control_mode_t control_mode;
} robot_t;
unsigned long interval;
unsigned long currentMicros, previousMicros;
volatile uint16_t encoder_delta[NUM_MOTORS];
int odo[NUM_MOTORS];
float v_wheel[NUM_MOTORS];
float v_wheel_ref[NUM_MOTORS];
robot_t robot;
VL53L0X sensor;
float distance, prev_distance;
#pragma GCC push_options
#pragma GCC optimize ("O3")
void timer_interrupt(void){
byte b, new_state;
static int8_t encoder_table[16] = {0, 1, -1, 0, -1, 0, 0, 1, 1, 0, 0, -1, 0, -1, 1, 0};
static byte encoder_state[2];
b = PIND;
new_state = (b >> 2) & 0x03; // Put encoder 0 channels in the lowest bits
encoder_delta[0] += encoder_table[encoder_state[0] | new_state];
encoder_state[0] = new_state << 2;
new_state = (b >> 4) & 0x03; // Put encoder 1 channels in the lowest bits
encoder_delta[1] += encoder_table[encoder_state[1] | new_state];
encoder_state[1] = new_state << 2;
static void set_motor_PWM(byte motor, volatile int new_PWM) // Motor control
if (motor == 0) set_M1_PWM(new_PWM);
else if (motor == 1) set_M2_PWM(new_PWM);
void set_robot_state(robot_t& robot, uint8_t new_state){
if (robot.state != new_state) { // if the state chnanged tis is reset
robot.prev_state = robot.state;
robot.state = new_state;
robot.tes = millis();
robot.tis = 0;
void obstacle_dodge(){
pinMode(encoder0A_pin, INPUT_PULLUP);
pinMode(encoder0B_pin, INPUT_PULLUP);
pinMode(encoder1A_pin, INPUT_PULLUP);
pinMode(encoder1B_pin, INPUT_PULLUP);
pinMode(M1_dir_pin, OUTPUT);
pinMode(M2_dir_pin, OUTPUT);
pinMode(M1_PWM_pin, OUTPUT);
pinMode(M2_PWM_pin, OUTPUT);
interval = 40UL * 1000UL;
LED_state = 1;
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LED_state);
Timer1.attachInterrupt(timer_interrupt);
Timer1.initialize(40); //uS
Timer1.pwm(TIMER1_A_PIN, 0);
Timer1.pwm(TIMER1_B_PIN, 0);
set_motor_PWM(0, 0);
set_motor_PWM(1, 0);
Wire.begin();
sensor.setTimeout(500);
while (!sensor.init()) {
Serial.println(F("Failed to detect and initialize sensor!"));
delay(100);
qtr.setTypeAnalog();
qtr.setSensorPins((const uint8_t[]){1, 2, 3, 6, 7}, SensorCount);
qtr.setSamplesPerSensor(NUM_SAMPLES);
calibration();
previousMicros = micros();
robot.state = 10;
byte i, l;
if(sensor.readRangeAvailable()) { // distance measurement
prev_distance = distance;
distance = sensor.readRangeMillimeters() * 1e-3;
currentMicros = micros();
if (currentMicros - previousMicros >= interval) {
previousMicros = currentMicros;
LED_state = !LED_state;
// Read Encoders
for(i = 0; i < NUM_MOTORS; i++) {
noInterrupts();
odo[i] = encoder_delta[i];
encoder_delta[i] = 0;
interrupts();
// Start new distance measure
sensor.startReadRangeMillimeters();
for(i = 0; i < NUM_MOTORS; i++) { //Wheel Speed
v_wheel[i] = TWO_PI * WHEEL_RADIUS / (2 * 1920.0 * DT) * odo[i];
robot.ve = (v_wheel[0] - v_wheel[1]) / 2;
robot.we = (v_wheel[0] + v_wheel[1]) / WHEEL_DIST;
robot.ds = robot.ve * DT;
robot.dtheta = robot.we * DT;
robot.rel_s += robot.ds;
robot.rel_theta += robot.dtheta;
v_wheel_ref[0] = robot.v + robot.w * WHEEL_DIST / 2;
v_wheel_ref[1] = robot.v - robot.w * WHEEL_DIST / 2;
position = qtr.readLineBlack(sensorValues);
if(distance < 0.25){
robot.state = 1;
}else{
robot.state = 10;
//What to execute in each state
if (robot.state == 1) { // The robot is stopped
M_PWM_value[0] = 0;
M_PWM_value[1] = 0;
}else if (robot.state == 10) { // Test
PID_control();
for(l = 0; l < NUM_MOTORS; l++) {
noInterrupts();
set_motor_PWM(l, M_PWM_value[l]);
interrupts();
For some reason, the robot spontaneously starts spinning and it doesn't stop until I reset it. This becomes worse as I increase the values of Kp, Ki or Kd reaching a point where it doesn't even try to follow the line, as soon as it enters the loop, it spins. At first I expected it to be some kind of variable overflow but I printed most of the values that I am using and they are far from their limit. My main suspicion now is that as I increase these constants, the motors can sometimes switch their direction very fast and that might cause some sort of trouble....
I pretty much ran out of ideas as to what could be causing this and possible solutions. I would appreciate if someone could give me some help.
