Line follower stops by black line
Hello
I have a code for a line follower, it is intended that my robot follow the black line, but he stops at the black line! Does anyone know what that may lie: mounting the sensor, code or … Kan somebody look at my code and tell me what’s wrong is?
I use:
Arduino UNO
Adafruit motorshield
Pololu Qtr-8rc sensor (i use 5 sensors)
2x Pololu meta gear motor 30:1
Thanks before
Ps: THE comment are in dutch because i am from Belgium
#include <QTRSensors.h>
#include <AFMotor.h>
AF_DCMotor motor1(1, MOTOR12_64KHZ);
AF_DCMotor motor2(2, MOTOR12_64KHZ);
#define KP .2
#define KD 5
#define M1_DEFAULT_SPEED 50
#define M2_DEFAULT_SPEED 50
#define M1_MAX_SPEED 255
#define M2_MAX_SPEED 255
#define MIDDLE_SENSOR 3
#define NUM_SENSORS 5
#define TIMEOUT 2500
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
#define DEBUG 0
QTRSensorsRC qtrrc((unsigned char) { 4,5,6,7,8} ,NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
void setup() // voorbereiding
delay(1000); // 1000 miliseconden
manual_calibration(); // De methode wordt opgeroepen
set_motors(0,0); // De methode wordt opgeroepen
int lastError = 0;
int last_proportional = 0;
int integral = 0;
unsigned int sensors[5];
// Het aantal sensors definiëren
int position = qtrrc.readLine(sensors);
// 0 tot 5000, waarbij 0 betekent direct onder de sensor of de lijn werd verloren
int error = position - 2000;
// error = positie - 2000
int motorSpeed = KP * error + KD * (error - lastError);
// De snelheid van de motor is gelijk aan 0,2 * error + 5 * (error - lastError)
lastError = error;
// De lastError = error
int leftMotorSpeed = M1_DEFAULT_SPEED + motorSpeed;
// linkermotor = 150 + motorspeed
int rightMotorSpeed = M2_DEFAULT_SPEED - motorSpeed;
// rechtermotor = 150 + motorspeed
set_motors(leftMotorSpeed, rightMotorSpeed);
// Zet de motor snelheid op (linkermotorsnelheid, rechtermotorsnelheid)
void set_motors(int motor1speed, int motor2speed)
if (motor1speed > M1_MAX_SPEED ) motor1speed = M1_MAX_SPEED;
// limiet van de snelheid van motor 1
if (motor2speed > M2_MAX_SPEED ) motor2speed = M2_MAX_SPEED;
// limiet van de snelheid van motor 2
if (motor1speed < 0) motor1speed = 0;
// Houd motor 1 boven de 0
if (motor2speed < 0) motor2speed = 0;
// Houd motor 2 boven de 0
motor1.setSpeed(motor1speed);
// Zet de motorsnelheid van motor 1 om in rotatie per minuut
motor2.setSpeed(motor2speed);
// Zet de motorsnelheid van motor 2 om in rotatie per minuut
motor1.run(FORWARD);
// Laat de motor 1 voorwaarts rijden
motor2.run(FORWARD);
// laat de motor 2 voorwaarts rijden
void manual_calibration() {
int i;
for (i = 0; i < 250; i++)
// de kalibratie neemt enkele seconden
qtrrc.calibrate(QTR_EMITTERS_ON);
// Het zet de emitter pin aan
delay(20);
// met een tussenstop van 20 miliseconden
if (DEBUG) {
// Als het juist is, zendt de sensor de data naar de seriele output
for (int i = 0; i < NUM_SENSORS; i++)
// verhoog i, zolang i kleiner is dan het aantal sensors
Serial.print(qtrrc.calibratedMinimumOn*);*
// print de kalibratie tot een minimum bij een emitter pin die on is, bij sensor i
Serial.print(’ ');
// daarna een lege print
// print data naar de seriele output, als menselijke taal via de ASCII tabel
Serial.print(qtrrc.calibratedMaximumOn*);*
// print de kalibratie tot een maximum bij een emitter pin die on is, bij sensor i
Serial.print(’ ');
My guess is that the default speed of 50 might be too low. Try something higher like 100.
You should also use indentation and code brackets to make your code easier to read:
#define KP .2
#define KD 5
#define DEBUG 0
QTRSensorsRC qtrrc((unsigned char[]) {
  4,5,6,7,8}
, NUM_SENSORS, TIMEOUT, EMITTER_PIN);
void setup() { // voorbereiding
int lastError = 0;
int integral = 0;
  lastError = error;
void set_motors(int motor1speed, int motor2speed) {
  int i;
  for (i = 0; i < 250; i++) {
    delay(20);
  if (DEBUG) {
    for (int i = 0; i < NUM_SENSORS; i++) {
      Serial.print(qtrrc.calibratedMinimumOn[i]);
      Serial.print(' ');
      Serial.print(qtrrc.calibratedMaximumOn[i]);
      Serial.print(' ');
