Line follower trouble
hi
i found a code for line following and changed it to fit my project.
The movement control works have testet it. But the code to decide were the line is issent responding on the input it gets.
Help?
int qtiPin = 52; //c
int qti2Pin = 48; //h
int qti3Pin = 50; //v
int redbPin = 3;   //led
int greenbPin = 4; //led
int redaPin = 11;  //led
int greenaPin = 12;//led
int ledPin = 13;   //led
int raw1, raw2, raw3;
boolean sen1, sen2, sen3;
int lastline;
long result = 0;
int lineplace;
int line;
int median = 40;//the point between the black and the white surface
 pinMode(7,OUTPUT); //motorpins
 pinMode(6,OUTPUT);
 pinMode(8,OUTPUT);
 pinMode(9,OUTPUT);
long RCtime(int sensPin)//operating for Qti sensors
   long result = 0;
   pinMode(sensPin, OUTPUT);       // make pin OUTPUT
   digitalWrite(sensPin, HIGH);    // make pin HIGH to discharge capacitor
   delay(1);                       // wait a  ms to make sure cap is discharged
   pinMode(sensPin, INPUT);        // turn pin into an input and time till pin goes low
   digitalWrite(sensPin, LOW);     // turn pullups off - or it won't work
   while(digitalRead(sensPin)){    // wait for pin to go low
      result++;
   return result;                   // report results
void fremad()//foraward
  digitalWrite(7, LOW);
  digitalWrite(6, HIGH);
  digitalWrite(8, LOW);
  digitalWrite(9, HIGH);
void bagud()//backwards
  digitalWrite(7, HIGH);
  digitalWrite(6, LOW);
  digitalWrite(8, HIGH);
  digitalWrite(9, LOW);
void hojrespin()//spin right
void venstrespin()//spinleft
void hojre()//right
void venstre()//left
void stans()//stop
int getline()   //returns line position
raw1 = RCtime(qtiPin);
raw2 = RCtime(qti2Pin);
raw3 = RCtime(qti3Pin);
median = 40;//the point between the white and the black value
if (raw1 > median) //place the line "1" true(on line) "2" false(off line)
 sen1 = 1;
if (raw1 < median)
 sen1 = 0;
if (raw2 > median)
 sen2 = 1;
if (raw2 < median)
 sen2 = 0;
if (raw3 > median)
 sen3 = 1;
if (raw3 < median)
 sen3 = 0;
  sen1 = 100;
//line placement
if (sen2 == 1)//højre/right
  lineplace = -2;
if (sen1 == 1 && sen2 == 1)//mellem højre og center/between right and center
  lineplace = -1;
if (sen1 == 1)//center/center
  lineplace = 0;
if (sen1 == 1 && sen3 == 1)//mellem center og venstre/between center and left
  lineplace = 1;
if (sen3 == 1)//venstre/left
  lineplace = 2;
if (sen1 == 0 && sen2 == 0 && sen3)//væk/gone
 lineplace = -10;
if (sen1 == 1 && sen2 == 1 && sen3 == 1)//over det hele/all black
 lineplace = 10;
return lineplace;
   line = getline();
  while (line == 0)
    fremad();
    lastline = 0;
    digitalWrite(greenaPin, HIGH);
  while (line == 1)
    fremad();
    lastline = 1;
  while (line == -1);
    fremad();
    lastline = -1;
    digitalWrite(redaPin, HIGH);
    while (line == -2)
    hojre();
    lastline = -2;
    digitalWrite(redaPin,HIGH);
    while (line == 2)
    venstre();
    lastline = 2;
    digitalWrite(redbPin,HIGH);
    while (line == -10)
    if (lastline == -2)
      hojrespin();
      digitalWrite(greenbPin,HIGH);
    if (lastline == 2)
      venstrespin();
      stans();
      digitalWrite(redbPin, HIGH);
    while (line == 10)
    venstrespin();
  Serial.print("sen1 ");
Serial.println(sen1);
Serial.print("sen2 ");
Serial.println(sen2);
Serial.print("sen3 ");
Serial.println(sen3);
Serial.print("raw1 ");
Serial.println(raw1);
Serial.print("raw2 ");
Serial.println(raw2);
Serial.print("raw3 ");
Serial.println(raw3);
Serial.print("line");
Serial.println(line);
