Line Follower won't turn right
I’m using an Arduino Redbot, with three line sensors. The car will follow the track, but won’t turn right. When it loses the track, it will just turn left until it picks something up, follows it, loses it, and repeat.
This is the script I have:
#include <RedBot.h>
RedBotSensor IRSensor1 = RedBotSensor(A3); // right sensor
RedBotSensor IRSensor2 = RedBotSensor(A6); // center sensor
RedBotSensor IRSensor3 = RedBotSensor(A7); // left sensor
RedBotMotors motors;
int leftSpeed; // variable used to store the leftMotor speed
int rightSpeed; // variable used to store the rightMotor speed
int SPEED = 60;
int LINE = 925;// level to detect if the sensor is on the line or not
Serial.begin(2000);
// if on the line drive left and right at the same speed (left is CCW/ right is CW)
if(IRSensor2.read() > LINE)
leftSpeed = -SPEED;
rightSpeed = SPEED;
// if the line is under the right sensor, adjust relative speeds to turn to the right
if(IRSensor3.read() > LINE)
leftSpeed = -(SPEED + 10);
rightSpeed = SPEED - 10;
if(IRSensor1.read() > LINE)
leftSpeed = -(SPEED - 10);
rightSpeed = SPEED + 10;
// if the line is under the left sensor, adjust relative speeds to turn to the left
if((IRSensor1.read() > 950) && (IRSensor2.read() > 950) && (IRSensor3.read() > 950)){
motors.brake();
motors.rightMotor(80);
motors.leftMotor(30);
// if all sensors are on black or up in the air, stop the motors.
if((IRSensor1.read() < 950) && (IRSensor2.read() < 950) && (IRSensor3.read() < 950)){
motors.brake();
do{
motors.leftMotor(-30);
while((IRSensor2.read() < 950));
motors.leftMotor(leftSpeed);
motors.rightMotor(rightSpeed);
delay(10); // add a delay to decrease sensitivity.
Any idea what I could to do fix this?
The names are stupid. If they were RightSensor, CenterSensor, and LeftSensor, the comments would be unnecessary.
Threshold values should be named appropriately. That value will not change while the program is running, so it should be const.
Comments should precede the block of code that they go with, not follow it.
I really can't follow your program logic, because the comments are so weirdly placed.
For everyone’s sake here is the code in code tags and Auto Formatted to make it easier to read
#include <RedBot.h>
int SPEED = 60;
  Serial.begin(2000);
  if (IRSensor2.read() > LINE)
    leftSpeed = -SPEED;
    rightSpeed = SPEED;
  if (IRSensor3.read() > LINE)
  if (IRSensor1.read() > LINE)
  if ((IRSensor1.read() > 950) && (IRSensor2.read() > 950) && (IRSensor3.read() > 950))
    motors.brake();
  if ((IRSensor1.read() < 950) && (IRSensor2.read() < 950) && (IRSensor3.read() < 950))
    motors.brake();
    do
    while ((IRSensor2.read() < 950));
OP - please take note
