Line following detection
Hi all-
We are using this Infrared line following sensor to detect the line on our robot. It will be used in conjunction with the Mega2560.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/28034/List/0/SortField/4/ProductID/729/Default.aspx
When any one of the LEDs detects the line, it returns a digital HIGH at 3V. Will this be enough to make the pins on the arduino go HIGH? I realize this is a pretty uncommon voltage... with 5V or 3.3V being the norm. Thoughts?
The threshold is 0.6 times the nominal voltage. So on a 5V system the threshold is 3V and your signal is not high enough to rely on. With a 3.3V system the threshold would be about 2V so you would be OK.
So, since I believe (correct me if I'm wrong) that the mega2560 is a 5V system, what would be my best option going forward so that I can accurately detect HIGH values from the sensor?
Thanks!
It would be best to put the signal through a transistor first.
