Line following doesn't work.
Dear people,
We've been playing around with the arduino for a bit, and so far we were good.
We tried the standard line following code, we uploaded it to our arduino and put it on a track.
But when we put it on the line, it turned around for a bit and stopped with the message: Time passed: 2385 Done!
But after that it did nothing. What did we do wrong? We googled for a bit and tried some other code but that wasn't working either. The robot we're using is the Arduino Robot 65237.
Thanks in advance!
It's really hard for us to know what you're talking about without more information.
What code are you using? You can post it here by using this:
Put your code here, selected by the "#" symbol above the smiles
Maybe a link to the robot your using?
First of all, thank you very much for your reaction.
We are using the standard code.
/* Robot Line Follow
 This sketch demonstrates the line following capabilities
 of the Arduino Robot. On the floor, place some black
 electrical tape along the path you wish the robot to follow.
 To indicate a stopping point, place another piece of tape
 perpendicular to the path.
 Circuit:
 * Arduino Robot
 created 1 May 2013
 by X. Yang
 modified 12 May 2013
 by D. Cuartielles
 This example is in the public domain
#include <ArduinoRobot.h> // include the robot library
long timerOrigin; // used for counting elapsed time
  // initialize the Robot, SD card, display, and speaker
  Robot.begin();
  Robot.beginTFT();
  Robot.beginSD();
  Robot.beginSpeaker();
  // show the logots on the TFT screen
  Robot.displayLogos();
  Robot.drawBMP("lf.bmp", 0, 0); // display background image
  Robot.playFile("chase.sqm");  // play a song from the SD card
  // add the instructions
  Robot.text("Line Following\n\n place the robot on\n the track and \n see it run", 5, 5);
  Robot.text("Press the middle\n button to start...", 5, 61);
  Robot.waitContinue();
  // These are some general values that work for line following
  // uncomment one or the other to see the different behaviors of the robot
  // Robot.lineFollowConfig(11, 5, 50, 10);
  Robot.lineFollowConfig(14, 9, 50, 10);
  //set the motor board into line-follow mode
  Robot.setMode(MODE_LINE_FOLLOW);
  // start
  Robot.fill(255, 255, 255);
  Robot.stroke(255, 255, 255);
  Robot.rect(0, 0, 128, 80); // erase the previous text
  Robot.stroke(0, 0, 0);
  Robot.text("Start", 5, 5);
  Robot.stroke(0, 0, 0); // choose color for the text
  Robot.text("Time passed:", 5, 21); // write some text to the screen
  timerOrigin=millis(); // keep track of the elapsed time
  while(!Robot.isActionDone()) {  //wait for the finish signal
    Robot.debugPrint(millis()-timerOrigin, 5, 29);  // show how much time has passed
  Robot.text("Done!", 5, 45);
  //nothing here, the program only runs once. Reset the robot
  //to do it again!
This is the robot that we're using: http://arduino.cc/en/Main/Robot
