I'm using the pololu QTR-8 sensor to follow a line. This is my code:
#include <QTRSensors.h>
int motorRechtsSpeed = 6;
int motorlinksSpeed = 8;
int moterRechts = 7;
int moterLinks = 9;
int maxspeedrechts = 100;
int maxspeedlinks = 100;
int defaultspeedrechts = 50;
int defaultspeedlinks = 50;
// Change the values below to suit your robot's motors, weight, wheel type, etc.
#define KP .2
#define KD 5
//#define M1_DEFAULT_SPEED 50
//#define M2_DEFAULT_SPEED 50
//#define M1_MAX_SPEED 200
//#define M2_MAX_SPEED 200
#define MIDDLE_SENSOR 3
#define NUM_SENSORS 5 // number of sensors used
#define TIMEOUT 2500 // waits for 2500 us for sensor outputs to go low
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
#define DEBUG 0 // set to 1 if serial debug output needed
QTRSensorsRC qtrrc((unsigned char[]) { 21,20,19,18,17,16,15,14} ,NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
pinMode(moterRechts, OUTPUT);
pinMode(moterLinks, OUTPUT);
pinMode(motorRechtsSpeed, OUTPUT);
pinMode(motorlinksSpeed, OUTPUT);
digitalWrite(moterRechts, HIGH);
digitalWrite(moterLinks, HIGH);
manual_calibration();
set_motors(0,0);
int lastError = 0;
int last_proportional = 0;
int integral = 0;
unsigned int sensors[5];
int position = qtrrc.readLine(sensors);
int error = position - 2000;
int motorSpeed = KP * error + KD * (error - lastError);
lastError = error;
int leftMotorSpeed = defaultspeedrechts + motorSpeed;
int rightMotorSpeed = defaultspeedlinks - motorSpeed;
// set motor speeds using the two motor speed variables above
set_motors(leftMotorSpeed, rightMotorSpeed);
void set_motors(int motor1speed, int motor2speed)
if (motor1speed > maxspeedrechts ) motor1speed = maxspeedrechts ; // limit top speed
if (motor2speed > maxspeedlinks ) motor2speed = maxspeedlinks; // limit top speed
if (motor1speed < 0) motor1speed = 0; // keep motor above 0
if (motor2speed < 0) motor2speed = 0; // keep motor speed above 0
analogWrite(motorRechtsSpeed, motor1speed); // set motor speed
analogWrite(motorlinksSpeed, motor2speed);
void manual_calibration() {
int i;
for (i = 0; i < 250; i++) // the calibration will take a few seconds
qtrrc.calibrate(QTR_EMITTERS_ON);
delay(20);
if (DEBUG) { // if true, generate sensor dats via serial output
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn[i]);
Serial.print(' ');
Serial.print(qtrrc.calibratedMaximumOn[i]);
Serial.print(' ');
But my robot is turning very slow how can i modify this?
And i can't use 8 sensors the code is made for 5
1- Error must be equal to "abs(setpoint-position)"
2- You are using 5 sensors but in the definition part you have given 8 sensor inputs "QTRSensorsRC qtrrc((unsigned char[]) { 21,20,19,18,17,16,15,14} ,NUM_SENSORS, TIMEOUT, EMITTER_PIN);"
3- If you don't have an emitter pin you have to define it as"#define EMITTER_PIN QTR_NO_EMITTER_PIN"
kaanmcetin:
Hi how does the "abs(setpoint-position)" works?
What must be added to my code?
I have this code with the pololu qtr -8 with the arduino mega. How can i modify this code that when the robot turns, one wheel turns the other way so the curves are sharper?
int moterLinks = 9;
#define KP .2
#define KD 5
QTRSensorsRC qtrrc((unsigned char[]) { 18,17,16,15,14} ,NUM_SENSORS, TIMEOUT, EMITTER_PIN);
set_motors(0,0);
int lastError = 0;
int integral = 0;
int line_position=0;
lastError = error;
int i;
delay(20);
Serial.print(' ');
Serial.print(' ');
