Line Following Trouble
Dear Forum,
I am typing this quickly, and somewhat frantically, so please forgive any typos. I am bilding a robot (4 wheels) that is designed to use 3 sparkfun reflectance sensors to follow lines, and an ultrasonic sensor so that the robot will stop when something is in front of it. I have 4 dc motors, being controlled by an Adafruit motorshield V2. I have gotten the ultrasonic sensor to work, and the robot moves, until something is in front of it. The line sensing is a different story. The robot moves, turns a little sometimes, but generally moving just straight. Here is my code:
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
Adafruit_MotorShield motorShield = Adafruit_MotorShield();   //motorShield object
Adafruit_DCMotor *motorFR = motorShield.getMotor(1);        // create instances of motors
Adafruit_DCMotor *motorFL = motorShield.getMotor(2);
Adafruit_DCMotor *motorBR = motorShield.getMotor(3);
Adafruit_DCMotor *motorBL = motorShield.getMotor(4);
long inches;
long duration;
const int pingPin = 7;        //ultrasonic sensor on pin 7
const int distance = 6;       // closest it can be
int rightIR = A5;
int centerIR = A4;
int leftIR = A3;               //connected to analog 0
int LSpeed;
int RSpeed;
int speedR;
int speedL;
int lineSense() {
  int leftVal = ((analogRead(leftIR) - 200) - ((analogRead(leftIR) - 200) % 50));
  int centerVal =  ((analogRead(centerIR) - 150) - ((analogRead(centerIR) - 150) % 50));
  int rightVal =  ((analogRead(rightIR) - 300) - ((analogRead(rightIR) - 300) % 50));
  int movingDirection = (centerVal + leftVal) - (rightVal + centerVal);  //or minus???
  Serial.print("The left value is: ");
  Serial.println(leftVal);
  Serial.print("The right value is: ");
  Serial.println(rightVal);
  Serial.print("The drift is: ");
  Serial.println(movingDirection);
  return movingDirection;
void follow(int drift) {
  lineSense();
  if (drift > 25) {
    speedR--;
    speedL++;
    Serial.print("speed R is:");              //for debugging
    Serial.println(speedR);
    motorFR->setSpeed(speedR);
    motorBR->setSpeed(speedR);
    Serial.print("speed L is:");
    Serial.println(speedL);
    motorFL->setSpeed(speedL);               //set the speed
    motorBL->setSpeed(speedL);
    if (drift < -25) {
      speedL--;        //decrease the speed of the left - needs to get over right
      speedR++;
     // delay(1000);
      motorFR->setSpeed(speedR - 60);
      motorBR->setSpeed(speedR - 60);
      //delay(1000);
      motorFL->setSpeed(speedL - 60);
      motorBL->setSpeed(speedL - 60);
long detectObject() {
  pinMode(pingPin, OUTPUT);          // Set pin to OUTPUT
  digitalWrite(pingPin, LOW);        // Ensure pin is low
  delayMicroseconds(2);
  digitalWrite(pingPin, HIGH);       // Start ranging
  delayMicroseconds(5);              //   with 5 microsecond burst
  digitalWrite(pingPin, LOW);        // End ranging
  pinMode(pingPin, INPUT);           // Set pin to INPUT
  duration = pulseIn(pingPin, HIGH); // Read echo pulse
  inches = duration / 74 / 2;
  return inches;                //return distance to nearest object in inches
void moveForward() {
  motorFR->run(FORWARD);          //all motors run forward
  motorFL->run(FORWARD);
  motorBR->run(FORWARD);
  motorBL->run(FORWARD);
void stopMotor() {
  motorFR->run(RELEASE);          //all motors stop
  motorFL->run(RELEASE);
  motorBR->run(RELEASE);
  motorBL->run(RELEASE);
  motorShield.begin();
  motorFR->setSpeed(70);      // set default speed for all the motors
  motorBR->setSpeed(70);
  motorBL->setSpeed(70);      //change vals depending
  motorFL->setSpeed(70);
  follow(lineSense());
  detectObject();            //look for object
  Serial.println(inches);   // print out how far the nearest
  if (inches < distance)     //if the nearest object is less than distance (6) away
    stopMotor();            //stop
    moveForward();
    Serial.println("movingForward");    //otherwise, keep moving forward
Please note the way the adafruit motor controller controls the dc motors is setSpeed function sets a speed, and run makes it go in whatever direction in relation to that speed. Note: RELEASE is stop.
How can I make the robot follow the line?
Thanks,
ma7730
I was using a Leonardo, but for some weird reason it stopped working, I couldn’t upload to it, so I switched to an Uno, but in the Serial monitor I just get: Estimated.
The lineSense() function pisses away 3 seconds every time it is called. No wonder you can't follow the line.
  lineSense();
When you do call it, you throw away the important information that it returns.
So, each call to follow() takes 6 seconds...
Why does detectObject() return a global variable?
Thank you so much for your quick response. I greatly appreciate it. When you say I waste away three seconds, am I correct to assume you are talking about the delays? I just deleted all the delays (except the ones in the detect object function, those are needed of course), and it still works exactly the same. I just moves forward until there is an obstacle.
What do you mean by saying that I am throwing away the important information when I call it?
The detectObject function returns a global variable so that when I call the function, in the main loop, I have
    stopMotor();            //stop
    moveForward();
It sees how far the object is and then sends that value to the variable inches, so I can see if that is fewer than 6, distance.
Thanks,
ma7730
You call the function:
  lineSense();
It returns a value. What are you doing with the value that it returns? You are discarding it. I fail to see how calling the function is useful.
Either the variable is local to the function, and you return the value in the variable OR the variable is global, and there is no need to return a value. Returning the value in a global variable is silly.
